dual mass clutch setup
Old May 14, 2014 | 10:01 PM
logger1989's Avatar
logger1989
Hi, I am in need of a new clutch, so i went into napa and asked them for a clutch set for a zf-5. The guy said I have to either have to convert to a single mass or replace the dual mass. Is this true? I know a replacement dual mass would be close to a grand I am really just trying to get a new clutch in before hay season as cheap as possible. thanks,
Kyle.
Old May 14, 2014 | 10:10 PM
Macrobb's Avatar
Macrobb
Either way is going to be expensive.
You could also try going to a junk yard and see if you can't pick something up that will work well enough for a while -- it sounds like this isn't a daily driver, so if you can get something that'll work for a few thousand miles, you'll be good.
Old May 14, 2014 | 10:15 PM
logger1989's Avatar
logger1989
so just to be sure there is no way to re-use the flywheel?
Old May 14, 2014 | 10:24 PM
Red454sedgwick's Avatar
Red454sedgwick
What problem are you having with your clutch? you can reuse the duel mass part if it is not messed up and check out rock auto.com Napa is expensive and the quality of parts isn't great
Old May 14, 2014 | 10:28 PM
logger1989's Avatar
logger1989
the disk is just stripped and im sure the pressure plate isnt good either
Old May 14, 2014 | 10:38 PM
Red454sedgwick
you should be able to just get those
Old May 14, 2014 | 10:43 PM
JWC 3's Avatar
JWC 3
You can have yours rebuilt . I would switch from the dual mass , if it were mine ...
Old May 14, 2014 | 10:45 PM
Red454sedgwick
NCF 1107100
there's your Napa part number for what you want I can get it for $230
LUK 07100
same part rock auto $170
Old May 14, 2014 | 11:34 PM
madpogue's Avatar
madpogue
DM flywheel is a ticking time bomb. You'll pay a LOT more later if you continue to use it, and it grenades the tranny case. Leverage the time/effort/money invested dropping the tranny and do it now; it'll save you in the end.
Old May 15, 2014 | 06:52 AM
tjc transport's Avatar
tjc transport
i ain't rite
Originally Posted by Red454sedgwick
NCF 1107100
LUK 07100
agreed. dump the dual mass garbage and put a single mass LUK setup in it.
Old May 15, 2014 | 10:43 PM
Red454sedgwick
Sorry that's just the upgrade 12 for the dual mass, new pressure plate and friction disk
Old May 15, 2014 | 11:31 PM
Muddy74Ford's Avatar
Muddy74Ford
Dual Mass can be a real pain in the *** to get resurfaced, alot of places dont want to do it... and in all honestly I agree with most of the above comments, all it is is a ticking time bomb... there is hardly any real need for the Dual Mass and the Solid Flywheel is the way to go. I can not tell you how many times I have seen destroyed transmissions from a Dual Mass going "Critical Mass" and blowing up... It's worth going to the Solid Flywheel while you are in there.
jsmahan
20
Oct 15, 2008 12:34 AM
rdmytro
Apr 12, 2008 11:20 AM
fastturn
Jun 29, 2007 12:17 AM
matt71
Jun 1, 2007 01:30 AM
Rreed46578
Aug 1, 2004 08:57 PM
