Programming a B key
Old May 2, 2014 | 05:52 PM
gfmk's Avatar
gfmk
Programming a B key
2003 Ex 6.0 got all my other issues solved .So now I want an extra transponder key cause I was getting a key circuit loop failure.So when using AE proline to program I get nowhere soon as I click done I get security failed....Now that being said I checked my diagnostic codes and B-1342 is there.ECU is bad.Am I doomed and have to replace.Also I have a tuner installed (HyperTech) set at level #2 cause i am scared of level #3.Even if I set tuner back to factory I still get Code #U0306.Is it possible the Tuner has corrupted ECU .......This is not a big deal but I would like a spare key
Old May 2, 2014 | 06:18 PM
04badford's Avatar
04badford
Im not to sure the 03s are compatible you may have to have a transponder or take it to Ford, have you tried a new key fob and turn the Ignition 8 times , I'll get you a link
Old May 2, 2014 | 06:24 PM
04badford's Avatar
04badford
http://www.keylessride.com/default.asp
one of many
Old May 2, 2014 | 06:31 PM
gfmk's Avatar
gfmk
Hey Badford.I am keeping you busy.I got a key and fob from amazon for 20$ and programming fob was a piece of cake.The key is a transponder type(B).
Old May 2, 2014 | 06:32 PM
04badford's Avatar
04badford
this should get you going
Old May 2, 2014 | 06:36 PM
04badford's Avatar
04badford
That's all it takes is cycle 8 times . I was wondering why my fingers were sore LOL , Glad to help
Old May 3, 2014 | 04:06 AM
Yahiko's Avatar
Yahiko
I had a set of older fobs and they would not work with my 2001.
I still have the 2001 fobs and they do seem to work with the
2006.
I was reading the first post and the OP said transponder key.
The Super Duty trucks did not use them at that point in time.
I think the Ex did.
So the question is key fobs of ignition PATS keys?
At some point they changed the system so that you have to
have access to a special database and to get that you have to
call and give your registration number to get the code you need.
Also you may have to have a VCM or a VCMII with IDS to make any
changes even with the access numbers.
Here is some info I found. There is some info on OUT CODES and IN CODES
Have look at this first one.
http://www.obd2.com/support/reprog/d...learn_pats.pdf
http://www.bsecorp.com/files/techtips/FORD%20PATS.pdf
Sean
EDIT : To program a new PATS key you must already have two in hand or you have to use the IDS with a VCM.
toys4dlr
Sep 21, 2024 06:44 AM
MrBonez
Modular V8 (4.6L, 5.4L)
Oct 9, 2017 09:16 AM
No-Tyme
2004 - 2008 F150
21
Dec 6, 2010 04:12 PM
04expo80f250
Dec 15, 2007 03:33 PM
Hello
Apr 28, 2005 12:55 AM
