What a drag,, it does happen tho. They either strip or are seized in the housing. We keep a manifold cover on the shelf just for that. Kinda expensive lil buger. Iirc it's almost $100. Throw a hfcm plug in it also,, I'm sure you already knew bout that tho.
I have one of these and think its great. Question though, the o-ring for mine is bad, got crunched up in the threads. as a result I can't measure for size nor given for fuel do I assume any old oring can be used. any suggestions as to where to get a new oring or do I have purchase a new plug?
Purchase the cheaper OEM plug amd move the o ring onto your better brass one. It's either that or go through o rings with the part and see what you can find.....
WOW, Just checked out the upgraded plug... One would assume that when purchasing the Housing cover, which I just did for $237 wholesale from Ford, That the upgraded plug would be included.
U No What,, Screw Ford OEM, I will take my old plug and put it on the lathe and install a drain **** on it. Ill spend 2 hrs making one rather then give fors a dime for there upgrade.......
O-ring for the drain plug:
Buna #111
<TABLE style="WIDTH: 321pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=428 x:str><COLGROUP><COL style="WIDTH: 321pt; mso-width-source: userset; mso-width-alt: 15217" width=428><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 321pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=428>http://www.grainger.com/Grainger/items/1KEZ8</TD></TR></TBODY></TABLE>
(I am sure you can find one locally, but I thought I would post a link to a supplier)
You can get it in Viton also (but they are expensive):
<TABLE style="WIDTH: 321pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=428 x:str><COLGROUP><COL style="WIDTH: 321pt; mso-width-source: userset; mso-width-alt: 15217" width=428><TBODY><TR style="HEIGHT: 13.2pt" height=18><TD style="BORDER-BOTTOM: #d4d0c8; BORDER-LEFT: #d4d0c8; BACKGROUND-COLOR: transparent; WIDTH: 321pt; HEIGHT: 13.2pt; BORDER-TOP: #d4d0c8; BORDER-RIGHT: #d4d0c8" class=xl24 height=18 width=428>http://www.dfuser.com/catalog/03-07-ford-f250f350-hfcm-water-separator-drain-plug-upgrade.php</TD></TR></TBODY></TABLE>
Wow,, I understand your frustration,, but blaming ford oem is "picture book" barking up the wrong tree. If it was me I'd be screaming about the "wholesale" pricing and the fact that whoever gave you that pricing didn't know to suggest the drain plug. You severely overpaid. A little research would've gotten you the correct setup,, at a much lower cost. I'm betting you paid full retail on the manifold.
