HFCM drain plug upgrade
Old Nov 2, 2013 | 01:38 AM
walkerfarms's Avatar
walkerfarms
Well my drain plug leaks now. Can I just get the new plug and install it with out taking anything apart or is housing stripped? I know I have seen this talked about before, but it takes hours going thru all these post trying to find something.
Hope some of you late nighters know so I can fix in the am.
Thanks in advance.
Old Nov 2, 2013 | 01:41 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Nothing to take a part to put in the new drain plug. Give it a try.
But, if it isn't the o-ring that is leaking and the threads are stripped, you might be looking at a new cover, which you will want to put the upgraded plug in anyway.
Old Nov 2, 2013 | 01:46 AM
walkerfarms
My gut is it is stripped. It doesn't seem to get tight at all. My nephew drove my truck for about 8 months and did filter changes before he gave it back. It had some fuel on it when I went to drain earlier today. Soon as I touched it, it seemed like it was loose. Now I can't get it to hold at all. Of course truck will not run with fuel pouring out the bottom.
How hard is cover to replace? I assume I will have to take the HFCM off. Crap, I had things to do tomorrow.
Old Nov 2, 2013 | 01:48 AM
walkerfarms
Do you know part # for the cover by any chance?
Old Nov 2, 2013 | 02:03 AM
lupuseven's Avatar
lupuseven
I know it sounds way redneck but if the new plug proves housing is stripped and you dont have time, money, or it will take time to get the new unit just put a small amount of JB weld, or anything that will seal it up, at the top of threads with the old plug. You wont have to get in there anytime soon this will allow you to run and give you time to get the replacement unit.
highly not recommended but if I was in a bind and truck need to be running...
good luck!
Old Nov 2, 2013 | 02:11 AM
lupuseven's Avatar
lupuseven
HFCM cover replacement:
https://www.ford-trucks.com/forums/9...fuel-pump.html
https://www.ford-trucks.com/forums/9...eing-hfcm.html
Old Nov 2, 2013 | 02:12 AM
lupuseven's Avatar
lupuseven
not sure if this is still good but its a start
HFCM part # - 6C3Z-9G282-C
EDIT just checked it its the full on unit not housing $3-400
Old Nov 2, 2013 | 02:21 AM
lupuseven's Avatar
lupuseven
6C3Z-9B249-B
I think this is it, I cant get a picture of it to come up when I searched for it.
price $162 and below
Old Nov 2, 2013 | 02:31 AM
walkerfarms
do you know difference between that part # and the A or B or C version? My truck is 2005 6.0
Old Nov 2, 2013 | 01:17 PM
Restlesswildman's Avatar
Restlesswildman
The kits should be inter changeable according to what I was told by local Ford SD dealer. I was told that all the manifold covers are the same over the years and HFCM configurations. I believe it was 05' and up that did away with the heater in the HFCM.
Old Oct 27, 2019 | 04:17 AM
Rockinfigs's Avatar
Rockinfigs
How often do you have to drain this thing.. I've owned my truck for about a yr now have 8k miles and never done it... Unless it was done by Ford when I got my first oil change.. How would I know if they drained it?
Old Oct 27, 2019 | 08:48 AM
SmackDaddy's Avatar
SmackDaddy
Just drain it now and then into a coffee can or something.
Old Oct 27, 2019 | 09:29 AM
TooManyToys.'s Avatar
TooManyToys.
Doing it is an important step.
dredmond
Jun 29, 2010 07:21 PM
65f100_352
Mar 19, 2008 02:35 AM
jaybe
Jun 24, 2007 07:54 PM
yomamaha
Jul 14, 2003 11:43 PM
