HFCM drain plug issues!
Old Sep 22, 2013 | 06:15 PM
Restlesswildman's Avatar
Restlesswildman
Question HFCM drain plug issues!
I went to drain the HFCM today to bleed off the fuel pressure and found the BRASS OEM plug stripped. I have a replacement on hand and was going to replace it.
Does anyone have any recommendations short of pulling the HFCM from the rail and pulling the plate and drilling the center out of the plug, then using a high end easy-out to remove it?
If I have to go that route, is there a gasket kit for the HFCM? If I have it on the bench, I will pull the pump and filter and clean the housing out.
Old Sep 22, 2013 | 06:39 PM
Yahiko's Avatar
Yahiko
The old plug should be steel.
Sean
Old Sep 22, 2013 | 07:33 PM
99ExpyProblems's Avatar
99ExpyProblems
lots of ideas here before you resort to pulling the cover... Of course, that may be your best bet anyway to take a look/get a better access.
https://www.ford-trucks.com/forums/9...lp-please.html
Old Sep 22, 2013 | 09:20 PM
Restlesswildman
Thanks 99Expy for the link!
I have the disconnect tools, might be my best bet to just pull it as a unit.
When I changed the filter in May or June there was quite a bit of junk in the HFCM. I am thinking it might worth the time to pull it apart and clean it. If I can get gaskets I will.
Old Sep 22, 2013 | 10:18 PM
Yahiko's Avatar
Yahiko
Found a HFCM Youtube for you
And for everyone else some diesel fun
Sean
Old Sep 23, 2013 | 03:15 PM
KINGDAR's Avatar
KINGDAR
Mine stripped on me also, it was alum. with an oring. Then I drilled out the hole and tapped it to fit a 1/2" pipe plug.
Old Sep 23, 2013 | 04:23 PM
Yahiko's Avatar
Yahiko
I'll have to go and see what it is made of. It's hanging
out in my used parts box.
Sean
Old Sep 23, 2013 | 04:42 PM
Restlesswildman
I thought I read on here somewhere that the 03's were brass. Mine looks like brass, but it is not in the best shape.
Old Sep 23, 2013 | 08:44 PM
KINGDAR's Avatar
KINGDAR
Correction My plug was steel. Mine stripped the threads out of the body.
Old Sep 24, 2013 | 12:47 AM
2civicrr's Avatar
2civicrr
I don't honestly remember what my original drain plug was made of. I do remember it was soft. That hex was starting to round off pretty early on. I just bought a new oem when I heard about the better option. I keep the new oem in the center console as a backup.
So much easier to use the knurled **** style.
Part# 6E7Z-9C082-A. Used to have to buy from International or aftermarket. You can get from dealer now too.
walkerfarms
Oct 27, 2019 09:29 AM
fluidp
May 3, 2014 05:02 PM
atomicglock
Jun 10, 2012 05:23 PM
dredmond
Jun 29, 2010 07:21 PM
427ford
May 9, 2009 01:49 PM
