won't start
Old Apr 25, 2014 | 05:32 PM
hunter444's Avatar
hunter444
won't start
It won't start when I push the clutch pedal but I can Start it under the hood what sensor is it that let the truck know when the pedal is pushed
Old Apr 25, 2014 | 05:36 PM
95_Dually's Avatar
95_Dually
Check the plug on the clutch pedal arm inside the cab. Make sure it's still connected.
Old Apr 25, 2014 | 05:37 PM
helifixer's Avatar
helifixer
there is a sliding switch in the rod where it goes through the firewall inside the cab. check your rod end if the plastic bushing is gone and has been gone for a while it can limit the travel of the rod. normally you have problems shifting before the switch doesn't move enough.
Old Apr 25, 2014 | 05:38 PM
hunter444's Avatar
hunter444
Is that the actuator arm that conects to the clutch master cylinder like a rectangle plug
Old Apr 25, 2014 | 05:42 PM
95_Dually's Avatar
95_Dually
Yes, that's it
Old Apr 25, 2014 | 06:10 PM
ReBilld's Avatar
ReBilld
Old Apr 25, 2014 | 06:33 PM
hunter444's Avatar
hunter444
The plastic retainer did fall off its back on and the plug is good it was just in the shop for the clutch master and slave cylinder
Old Apr 25, 2014 | 06:41 PM
95_Dually's Avatar
95_Dually
You possibly have a bad switch assembly
Old Apr 25, 2014 | 06:42 PM
95_Dually's Avatar
95_Dually
I'm not sure which wire you could jump to test the plug, but it sounds like the switch to me.
Old Apr 25, 2014 | 08:11 PM
madpogue's Avatar
madpogue
The two wires closest to the firewall on the connector, should both be red/blue, are for the starter circuit. You could disconnect the switch and put a jumper wire between those two terminals on the harness connector, and then it should start. But keep in mind, it will start in gear if you do this.
If you paid a shop to do the hydraulics, they should have reinstalled the switch properly, and evidently they didn't. You should take it back to them to fix it, as part of the original job.
Old Apr 30, 2014 | 12:00 AM
95_Dually's Avatar
95_Dually
Waiting for an update
Old Apr 30, 2014 | 06:52 AM
hunter444's Avatar
hunter444
Sorry guys I've been swamped with work I'm not shur if I did the wires right is there a way not to use the clutch any more to start it just the key ?
Old Apr 30, 2014 | 07:47 AM
madpogue's Avatar
madpogue
See post #10.
Old Apr 30, 2014 | 09:32 AM
hunter444's Avatar
hunter444
I must have missed that entire post sorry bout that well I am half @$$ color blind but yes that did work as soon as work slows down and I get a change to get home I'll have the wife bring it to the shop thanks guys
tpolley
Mar 10, 2015 02:39 AM
264WSM
Nov 16, 2012 07:37 AM
wildmand
Aug 22, 2012 05:19 PM
bad_habit59
May 3, 2008 02:02 PM
pucko94.5
Aug 26, 2007 01:44 PM
