Clutch engaged for starting
Old Aug 23, 2007 | 11:00 AM
pucko94.5's Avatar
pucko94.5
In my 94 PSD 5-speed, I feel like I have to push the the clutch in through the fire wall to get the starter to fire off. Is this a sensor problem or is there a dirty switch?
Old Aug 23, 2007 | 11:05 AM
MagKarl's Avatar
MagKarl
Check to see if the plastic bushing in the clutch master cylinder pushrod eye is worn out or missing. It keeps the pushrod eye centered on the pedal linkage rod. If it's worn out, the pushrod won't travel quite as far and your switch may be right on the edge of allowing the rig to start.
Old Aug 23, 2007 | 02:42 PM
Stroker 94 1/2's Avatar
Stroker 94 1/2
Check the no start switch on the clutch rod coming through the firewall. I had the same problem and the local auto parts store had it available.
Old Aug 25, 2007 | 09:39 PM
pucko94.5's Avatar
pucko94.5
The plastic bushing was shot and the pedal linkage rod was about out. Thanks for the help guys.
Old Aug 26, 2007 | 05:58 AM
Cuda_jim's Avatar
Cuda_jim
There is a better replacement for that plastic bushing it will likely fail again.
http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
Old Aug 26, 2007 | 07:30 AM
Neal 97 250's Avatar
Neal 97 250
Mine had the same problem. I temporary fixed it with new parts from the dealer. Go Cuda's route and you will be done forever. Get a good cutting tool though that metal is hard.
Old Aug 26, 2007 | 09:52 AM
MagKarl's Avatar
MagKarl
Anyone have a picture of the ebay rod end installed? Seems like a good fix.
Old Aug 26, 2007 | 01:44 PM
pucko94.5's Avatar
pucko94.5
Thanks Jim, its ordered.
83f250460ci
Nov 20, 2020 08:45 AM
countryboywatts
Jan 2, 2016 05:35 PM
giorgio.fo
17
Apr 13, 2014 11:01 PM
351W1085
Dec 13, 2012 12:58 AM
gnarkle
Nov 6, 2010 09:12 PM
