lift kit
Old Apr 29, 2014 | 02:57 PM
bigbadwolfe's Avatar
bigbadwolfe
lift kit
just as the title said i found a lifted 02 powerstroke in the bone yard my ? is will the leaf springs work in my truck ???
Old Apr 29, 2014 | 09:27 PM
tshrager's Avatar
tshrager
I believe you need to do an RSK to use the SD springs. Someone will correct me if I'm wrong.
Old Apr 30, 2014 | 09:24 AM
bigbadwolfe
is this true ?
Old Apr 30, 2014 | 11:36 AM
dclack's Avatar
dclack
Yes! The rear springs will fit, but they use a larger bolt, so you will have to drill out the spring hangars. The SD front springs are longer, so you will need this... OBS RSK SD Spring Hanger Conversion Kit
caleb6.9
Mar 7, 2010 12:22 PM
DougD
Feb 29, 2004 06:57 PM
95xltmud
Dec 19, 2002 08:46 AM
chilly390
Feb 12, 2002 02:57 PM
