Starting switch question
Old Aug 15, 2012 | 01:55 PM
wildmand's Avatar
wildmand
Hi Guys:
I'm having progressively more trouble getting the switch which the clutch pedal contacts to work. I have to press the pedal REALLY hard to the floor before the truck will start, well beyond the clutch engage/disengage point.
Anybody know what the mechanism for this is, and where it is, and whether it can be adjusted?
It's a 91 N/A 5 speed. Any help would be appreciated.
Cheers
Dale
Old Aug 15, 2012 | 10:01 PM
bashby's Avatar
bashby
Look right above the accelerator pedal, you'll see the clutch master cylinder rod and the clutch switch attached to it. There is a plastic bushing that caonnect the pushrod to the pedal assy., if it is worn you wont get the travel you should.. could cause your problem.
Old Aug 17, 2012 | 10:37 PM
airdale94's Avatar
airdale94
You can jumper the plug. You will lose the safety feature of the switch though.
Old Aug 18, 2012 | 01:10 AM
Bob_Smith's Avatar
Bob_Smith
+1
I do this to every vehicle I own as soon as I get it home. As long as you can trust yourself to not forget and try start the truck without the clutch down (while in gear) or without putting it in neutral, its the way to go IMO.
Old Aug 18, 2012 | 01:43 AM
vfelix702's Avatar
vfelix702
This is what i did been like this for 2 years now.... cuz i was having the same issue lol https://www.youtube.com/watch?v=WVt3...e_gdata_player
Old Aug 22, 2012 | 05:19 PM
wildmand's Avatar
wildmand
Thanks for the replies guys, good info. I've been away from the computer for a little while, I'll try to fix the switch and if not I'll wire around it as suggested.
Really appreciate the help, this site is great
Cheers
Dale
264WSM
Nov 16, 2012 07:37 AM
bigreddieselco
Mar 8, 2009 05:05 PM
4x4man514
Aug 28, 2004 01:12 AM
shendoa
Feb 5, 2004 05:52 PM
Kool Bronco
1978 - 1996 Big Bronco
Aug 18, 2003 05:05 PM
