Heater control unit issues!!!
Old Apr 25, 2014 | 02:10 PM
Restlesswildman's Avatar
Restlesswildman
Question Heater control unit issues!!!
Got in the truck today to head out of town and when I started it up I had ZERO POWER to the Heater control unit under the radio in the dash.
Pulled the fuses and checked all was good.
Called around no one was able to look at it until 2 weeks from last Thursday...
Decided to leave out on the road anyway. Stopped at a light waiting to make the turn to the highway and started pushing buttons in a last attempt and it powered up when I hit the last button on the bottom row towards the glove box.
Prior to this I pressed every button on the darn thing.
I would appreciate any input on this from any of the list techs. I am stumped!
Old Apr 25, 2014 | 03:51 PM
King-bRanch's Avatar
King-bRanch
Iam sorry I cant help u but in the last 3 years of owning my 2006 KR there has been 2 instances where my Temp Control Assembly (digital auto temp version) did not power up either, then it powered up normally after a key cycle both times.
Who knows why, I was just happy it turned back on
Old Apr 25, 2014 | 04:16 PM
KIDkiser's Avatar
KIDkiser
Mine has done the same thing a couple of times.usually I can turn the signal light on,or headlights on and off and it starts working again.
Old Apr 25, 2014 | 05:35 PM
Rusty Axlerod's Avatar
Rusty Axlerod
This is cut and paste from a previous thread:
"My "electronic" climate control sometimes doesn't power up when I start the truck (usually in hot weather). No temp display and nothing changes when you press the buttons. Usually it would work normally if I restarted the truck. Someone suggested flipping the headlights on. Crazy as it sounds it worked. I could understand how that might affect it if it was just the display being dead but how flipping the light switch could "wake up" the button functions is baffling.
Answer,
There have been several posts explaining this behavior. I have 'only' had this happen twice in my 3+ yrs of ownership..
The power saver circuit has a non-replacable relay on the instrument cluster that sticks off. The added power draw of the headlights triggers this relay into working properly."
Old Apr 25, 2014 | 07:27 PM
04badford's Avatar
04badford
Rusty is this electrical or the Vaccume issue ? to the OP look under the dash passenger side the heat control vaccume line that come from the control arm under the hood, there you will see a shinny canister with the vaccume line and electrical hook up, look to see if things are ( hooked up ) and not kicked out
Old Apr 25, 2014 | 07:33 PM
Rusty Axlerod
It was explained to me as electrical- sticking relay. I don't think the vacume would have to present for the control panel to come on. When you start the truck it's completely dead.
Old Apr 25, 2014 | 07:50 PM
04badford's Avatar
04badford
I gotcha thank you Sir ( darn relays)
Old Apr 27, 2014 | 07:00 AM
Restlesswildman
so if the relay goes bad, you have to replace the cluster? FUDGE!!!!
Old Apr 27, 2014 | 07:16 AM
KDAVID1's Avatar
KDAVID1
Mine did this yesterday. No display lights, ext temp, nothing. I shut the engine off and restarted. It started working as normal after that.
Old Apr 27, 2014 | 07:40 AM
Rusty Axlerod
Mine has done this 5 or 6 times since I owned the truck(4 years). It will have to become a lot more frequent before I'll put a dash cluster in it.
Old Apr 27, 2014 | 08:52 AM
69cj's Avatar
69cj
Mine did it while still under warranty. Dealer replaced the head unit and problem solved.
Old Apr 27, 2014 | 09:52 AM
KDAVID1's Avatar
KDAVID1
Yep I could go a good long while without ac before I pull the dash--not a fun thing
Old Apr 28, 2014 | 07:36 PM
Restlesswildman
Well it did it again today when I got in the truck after work.
Turned the truck off.....light on....and started the truck again and I had power and A/C!
Old Apr 28, 2014 | 08:37 PM
Per4mance's Avatar
Per4mance
Mine started doing that when I first got it on the road after reassembling it from the wreck. I fixed my problem by disconnecting the batteries and leaving the headlight switch on for a hour. I never have had the problem since....maybe I got lucky?
tfunk88
Aug 14, 2018 08:19 AM
GMUGNIER
6.7L Power Stroke Diesel
Aug 6, 2012 09:53 AM
KIDkiser
Dec 13, 2011 01:20 PM
8lug
Jun 19, 2011 07:47 PM
frederic
Feb 21, 2004 07:31 PM
