Heater Quit!
Old Dec 12, 2011 | 10:37 PM
KIDkiser's Avatar
KIDkiser
Heater Quit!
today when i ran in the store heater was working fine,came out started the truck and nothing! the lights on the climate control was out and no heater.so i figured i blew a fuse,so when i got home i pulled the fuses,and none were blown.so when i got in the truck to take it to the garage the heater was working,digital display was working and everything was good.so if its not broke you cant fix it.so now i just have to wait until it does it again,anybody ever have this happen.i figured it was maybe a corroded contact on one of the fuses,but thats generally not my luck,and i figure the digital climate control is pretty expensive.any body have any ideas.the truck is an 06 250 harley edition with 94,000 miles
Old Dec 13, 2011 | 01:33 AM
crmarshall's Avatar
crmarshall
I have had 2 trucks do it. Both 2005 models. Usually I notice it when I'm backing out of the driveway, I just stop, shut it off and restart and all is well. About 2 months ago it wouldn't come back on. I shut the truck off and started several times while running errands. I ended up pulling the climate control electrical connector off the back of the unit and reseating the plug. Havent had an issue since. I didn't even pull the dash, just reached up from underneath. Hope that helps. Good luck.
Old Dec 13, 2011 | 07:57 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Mine did this twice in a couple of weeks right after I got it. As crmarshall said, a restart would make it work. Didn't do anything to it but hasnt done it again in almost a year.
Old Dec 13, 2011 | 08:13 AM
j4henry's Avatar
j4henry
Mine has done it A few time when I used my auto headlamp and a couple without using them I found a thread the said to turn vehicle off and use key fob to lock doors then unlock with fob works everytime. Since I stopped using auto headlamps it's only done it once
Old Dec 13, 2011 | 11:32 AM
strokin83's Avatar
strokin83
I have an 05 as well mine does this a couple times a year. Usually if I turn the headlights on and off it starts working again. I don't know how the two are connected other than a dimmer switch but it always works. When mine does this the whole Climate control unit is off until I play with the lights. Strange I know.
Old Dec 13, 2011 | 01:20 PM
texans's Avatar
texans
I think they all do it now and again. My 06 does it once or twice a year
Shadowrider123
Apr 16, 2015 06:53 PM
Mdennis0_8
Nov 23, 2011 07:22 AM
BobbyFord
Nov 26, 2006 07:02 AM
UglyF250
Jan 16, 2002 05:38 PM
