Hello all my 05 F350 climate control quit working today. I went for a ride and it was working . I stopped at a store , came back out fired the tuck up and it would not come on. The display is blank. I checked the #23 and #24 fuses and they seem to be good. Not sure where to look next ?
This has happened to me a few times. I don't know that there's a real solution for it. I always just shut the truck off for a min then turn it back on and it will start working. If that don't work then you might have a bad unit. It has only happened to mine like 3-4 times in 5 years so I really don't think much about it when it happens.
I went out to look around the fuse box some more and turned my headlight switch on and the climate control popped back on WTF !! What would that be all about? Another mystery like my turn signals not wanting to work sometimes !!
Hello Mr Texans turning it off for a while was the first thing I tried . When that did not work and the fuses checked out okay I started getting nervous then I turned my headlights on and it popped back to life !! ??
This is not an uncommon problem. The solution is to just turn the headlights on and off just like you did and it will all come back to life. Always works.
