E4OD Shifts Hard
Old Apr 16, 2014 | 05:49 PM
Z94F350's Avatar
Z94F350
E4OD Shifts Hard
I have a 1994 E4OD Trans and it shifts hard and late. Im not sure what else to do to fix it and need help and other ideas. Last resort is pulling the trans and replacing it with a spare.
What I have done already
-Checked Fluid (its great and not burning)
-Emptied a qt of Trans fluid out and put a bottle of Lucas in. (nothing)
-Checked VSS / ABS sensor and the spedo is not jumping
- OD light is not flashing
-Checked Fuses
-Read the OBD codes only thing that popped up was the HEGO sensor says its <nobr>running</nobr> a bit lean
-Cleared the codes
-Replaced TPS Sensor
-Replaced <nobr>MLPS</nobr> Sensor
-Checked the wires on passenger side that connects to the Solenoid
If you have any ideas please help!!
Old Apr 16, 2014 | 06:53 PM
rla2005's Avatar
rla2005
Stick to one thread for the same issue....
https://www.ford-trucks.com/forums/1...ting-help.html
Ensue56
May 25, 2015 06:43 PM
landcruzr
Dec 23, 2009 06:35 PM
tandpr
Oct 6, 2009 08:42 PM
Biglame
Nov 7, 2008 08:32 PM
Jrock909
Dec 12, 2004 07:52 AM
