E4OD with blinking overdrive light
Old May 25, 2015 | 05:33 PM
Ensue56's Avatar
Ensue56
I have a 1996 E350 7.3 with a E4OD trans with a blinking overdrive light. I had the codes pulled and I'll list them below. Van has 189,000 on it and when I bought it I drove it 3 hours home and the trans felt great. It ended up having a number of motor issues and sat without starting for a year. The motor issues are resolved to the point it runs ok but now the trans is in limp mode with the blinking light. Van hauls *** in reverse but not so much in drive. What happened while it sat, could it have locked up? Any help or ideas would be greatly appreciated. Thanks, here are the codes that were pulled
P1280 icp circuit out of range ckt
P0713 trans fluid sensor high input
P0603 internal ctrl module kam error
P0478 exhaust ctrl valve high
P0470 exhaust sensor circuit fault
P0708 trans range sensor circuit high input
Old May 25, 2015 | 06:43 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You really should fix the engine codes before attempting to fix the trans. The TRS is showing an error. It is the sensor on the side of the trans. Either the sensor is bad or you have a bad wire to the sensor.
mototrig
18
Mar 22, 2016 08:22 AM
Z94F350
Apr 16, 2014 06:53 PM
ajorn
Feb 9, 2010 08:20 AM
IceboxFX
27
Mar 24, 2008 04:50 PM
RP27G8G
Jan 20, 2008 10:09 PM
