GPCM
Old Apr 14, 2014 | 06:01 PM
brandon.edwards's Avatar
brandon.edwards
GPCM
Will this part going bad cause rough "cold" starts? My truck doesnt fire as it should. And the only code im getting is P0683 meaning that the communication to the PCM from the GPCM is broken. I checked wiring harness and that seems all good. Soooo im thinking ill be replacing GPCM
Old Apr 14, 2014 | 09:56 PM
04badford's Avatar
04badford
Yes but not very often, double check the two connection the plastic clip brakes real easy and the connection will work back out, I had to zip tie mine
Old Apr 14, 2014 | 09:58 PM
brandon.edwards
Roger that. Ill check that tomorrow.
jpcnorthwood
Jul 25, 2011 08:19 PM
phantom02
Apr 29, 2011 06:58 PM
SkySkiJason
Apr 17, 2010 07:31 PM
SamMyers
Jan 29, 2007 02:34 PM
Ford510
Jan 9, 2007 12:45 PM
