P1316 DTC, am I wrong??
Old Jan 27, 2007 | 05:20 PM
SamMyers's Avatar
SamMyers
Unhappy P1316 DTC, am I wrong??
A few days ago, my 2000 F-350's CEL came on, and starting running a bit rough, like maybe 1-2 injectors were stuck. I checked the code that came up (P1316), and contacted by buddy at Ford. Say's it the IDM circuit having an issue. Perhaps the IDM itself, or some injectors.
I've been frantically going thru old posts, and have come up with the preliminary conclusion that it's the UVC harness connector. I'm going to open that up tomorrow to check.
Our weather (central Washington state), has been fairly cold for the last month. I don't know if this will contribute to the problem or not, but when the truck gets warm, then the problem seems to go away, until it's cold again.
Just need some comfirmation to know if I'm out in left field or not.
Thanks to all that reply.
Old Jan 27, 2007 | 05:48 PM
Uzumati's Avatar
Uzumati
If you can do a CCT, Buzz, and KOEO test with your scanner you may be able to pull those IDM Codes. The UVC harness is a likely culprit though and is easy enuff to check.
Old Jan 27, 2007 | 08:15 PM
basstardo's Avatar
basstardo
Check dis out bub...
https://www.ford-trucks.com/forums/5...harnesses.html
I had the same exact issue.
Old Jan 27, 2007 | 09:19 PM
clintbonnie's Avatar
clintbonnie
Just fixed mine.. same problem, same code.. It was a loose 9 pin connector just under the valve cover on the driver side... The plastic locking tabs are a poor design.. I just put a shim under the tabs to fix it.. Other people have bought Ford's fix, which is a plastic clip... Good Luck..
Old Jan 28, 2007 | 04:38 PM
SamMyers's Avatar
SamMyers
To all who have responded, Thank you.
One other question that I have. Has anyone had any experience with this issue repeating itself? How long did it take? The reason I ask, is that I only pushed the plug all the way back in under the valve cover. I'm not sure when I'll get back to it.
Thanks again,
Old Jan 28, 2007 | 06:05 PM
Uzumati's Avatar
Uzumati
It can work its way back out if you did not use the "new clips" Ford sells but who knows how long. They are farely cheap from international, maybe get a set and keep them in the glove box for when it comes back.
Old Jan 29, 2007 | 09:35 AM
John7894's Avatar
John7894
I did mine too. Haven't gotten that code again..... Buy the stuff from your local International dealer, Ford is about twice the price...
I'd make the time to fix it. Mine got so bad that it seemed like it would never get warm enough to "cure" itself.....
Old Jan 29, 2007 | 02:34 PM
CSIPSD's Avatar
CSIPSD
If your down in Oregon feel free to PM me and we can run a test or two on it!
scottddove
Jul 31, 2015 02:02 PM
Lerch7.3
Jun 24, 2015 07:53 AM
vegtoph
Dec 6, 2014 12:11 PM
Justin Jantzen
Sep 25, 2014 06:37 AM
greg_8507
Apr 7, 2014 07:27 PM
