do i sell or keep
Old Apr 10, 2014 | 11:07 AM
jeremy joe's Avatar
jeremy joe
Unhappy do i sell or keep
hi everyone i just bought 86 f150 with problems i was wondering can i take the emissions and the feed back system off and install aftermarket parts also i do need the complete wiring harness color code
Old Apr 10, 2014 | 01:06 PM
RL250's Avatar
RL250
You need to read your state and federal laws before we can make that determination regarding the emissions equipment. My 250 is an 81, which does not require emissions in Texas, but does in California. Also, once we know what stays and what goes we can give better guidance on the wiring.
Old Apr 10, 2014 | 02:53 PM
jeremy joe's Avatar
jeremy joe
carb distributor and all sensors i live in sc and as long as i do the work myself i think that i can do the conversion planning on putting a offenhauser intake a holley 4 bbl a vacume advance mallory distributor a mad super coil headers and custom gauges
Old Apr 10, 2014 | 03:00 PM
jeremy joe's Avatar
jeremy joe
my truck at on time came fully loaded but now all i have is a engine and a hacked up wiring harness the plugs for the sensors have been cut off and the vacume lines have been melted shut i do not have an ac heat at all and the fuse block has been messed with cause it has melted
Old Apr 10, 2014 | 03:02 PM
jeremy joe's Avatar
jeremy joe
im assuming that if i could get the color codes i can rebuild the factory harness to suit my needs
Old Apr 10, 2014 | 06:23 PM
reamer's Avatar
reamer
Just did all that on my '84 You can remove the complete wiring harness that comes from the "computer" (removed that too) got 3 wires coming from the dash, Oil, Temp, Tach, and 1 for ignition. That's it.
Old Apr 11, 2014 | 07:50 AM
jeremy joe's Avatar
jeremy joe
thanks im going to take some pics and post later
Old Apr 11, 2014 | 08:24 AM
BiGGreen350's Avatar
BiGGreen350
we just did the same on the uncles 84 f250 with a 351
mountain dewd
Jan 7, 2016 12:25 PM
Caveman2851
Mar 5, 2009 02:48 PM
71dusterdan
Electrical Systems/Wiring
Dec 18, 2008 05:46 PM
skelator84
Dec 13, 2005 09:23 AM
bolinb
Bronco II
Jun 23, 2003 12:01 AM
