main engine wiring harness shot.
Old Nov 22, 2005 | 04:39 PM
skelator84's Avatar
skelator84
Exclamation main engine wiring harness shot.
I have an 84 bronco with a carborated 351w and the wiring harness is too far gone to repair. i found a good harness out of an 88 f150 for 30$. they both are for 351w the newer truck is fuel injected and the older is carborated. will the newer harness work on the older engine? Im pretty sure it will if they both have the same type of ignition system am i right?
Old Nov 24, 2005 | 11:51 AM
TigerDan's Avatar
TigerDan
They'll be quite different. The EFI harness has the wiring for the injectors and sensors, and I don't think the plugs where it connects to the main harness will match up. Better that you look for one from a carbed engine closer in year to your Bronco.
Old Nov 27, 2005 | 04:40 PM
lisagoud's Avatar
lisagoud
I've got one out of a 1984 F150 5.0 with carb if interested...let me know is interested.
Old Nov 28, 2005 | 09:13 AM
rebocardo's Avatar
rebocardo
Unless you need it for carb emissions, there is no reason you can not add a aftermarket dist. with electronic ignition and a coil and ditch the Duraspark (?). Then you only need two wires, ignition on and 12+ positive.
Old Dec 13, 2005 | 09:23 AM
skelator84's Avatar
skelator84
its not duraspark its eec-4 with distributor mounted ICM
