1978 - 1996 Big Bronco
91 trans question
Old Apr 8, 2014 | 12:14 AM
rusty 91's Avatar
rusty 91
91 trans question
i needed a transmission for my 91 bronco. i found one on craigsllist and threw it in. every thing went well. only i dont have first gear or overdrive. if i put the truck in drive i think im starting in 3rd and the rest on the selector im starting in second gear. could this be because the trans is out of a truck that had a 302 and mine is the 5.8 and the computers are not talking? i have checked the linkage quite a few times and i know that it is right. any ideas?
Old Apr 8, 2014 | 07:28 AM
Fordman96's Avatar
Fordman96
They might not be talking, but I would think that there isn't a major difference in shift points from a truck 302 vs a truck 5.8.
How many miles are on the new trans when you bought it? Was it rebuilt? Did PO have a receipt if it was?
Old Apr 8, 2014 | 09:13 AM
Kemicalburns's Avatar
Kemicalburns
what year trans is it? I suspect we are talking about an E4OD as well correct? trans full of fluid? the MLPS may need replaced and or the solenoid pack.
Old Apr 8, 2014 | 09:44 AM
Conanski's Avatar
Conanski
Need more info. Your truck likely originally came with an E4OD, what transmission did you put back in? Are all the electrical connections plugged in or are there any wires left unplugged?
Old Apr 8, 2014 | 08:36 PM
rusty 91's Avatar
rusty 91
i dont rember the miles i did the swap several years ago ive just been driving like that. it wasent rebuilt it came out of a wrecked truck
Old Apr 8, 2014 | 08:39 PM
rusty 91's Avatar
rusty 91
the trans that went in was also a 91. yea its full. i dont know what a mlps is, is that something i can take out of my old tranny i still have it laying around
Old Apr 8, 2014 | 08:41 PM
rusty 91's Avatar
rusty 91
i do believe thats what i put back in, the oil pan was the same and the electronic plugs fit right on with no extra
Old Apr 8, 2014 | 08:59 PM
Fordman96's Avatar
Fordman96
the MLPS is the manual lever position sensor. Essentially it's the neutral safety switch right?
Old Apr 10, 2014 | 04:25 AM
rusty 91's Avatar
rusty 91
that has to do with starting not shifting. i can start in park or neutral
Old Apr 10, 2014 | 06:49 AM
Fordman96's Avatar
Fordman96
Kemical mentioned it is all. I was trying to figure out what it was.
yfz 450
18
May 22, 2012 02:20 PM
tim_c
Nov 6, 2011 10:16 PM
kickstarter
16
Apr 28, 2007 06:26 PM
91Bronco
Sep 2, 2001 10:46 PM
91Bronco
Sep 2, 2001 10:00 PM
