E4od question (hate these transmissions)
Old May 20, 2012 | 08:11 PM
yfz 450's Avatar
yfz 450
I have a 97 f350 with a 460. I just bought it last week I noticed when I am on the gas hard that when the trans shifts into 3rd it bumps in. It feels like it kicks in comes out then kicks back in. This happens within a mila second. I am just worried because last year I bought A f250 with the 351 and I hade to replace the trans within 2000 miles of buying it and I really don't have the cash for a new trans this time around. Does anyone have any idea if this is a bad sign?
Old May 20, 2012 | 08:17 PM
yfz 450's Avatar
yfz 450
Forgot to add the truck has 73,000 miles
Old May 20, 2012 | 08:59 PM
KC92F150's Avatar
KC92F150
I have a 97 with a Powerstroke with an E4OD (150,000 mi), my trans was kinda hitting hard on shifts and slipping going into OD. I had the trans serviced and has worked pretty good since (164,000 mi now).
One thing my trans don't like is between 35-40 MPG on surface roads, it don't really know weather to go into OD or downshift.
Anyway back to your trans. Maybe a service is in order before you make any decissions on what to do about it, if anything at all.
Hope this helps
Old May 20, 2012 | 09:08 PM
White 97 xlt's Avatar
White 97 xlt
First thing you need to do is check for any DTC codes..... these transmissions are COMPLETELY computer controlled, and any little thing can and will make them act funny....
Old May 20, 2012 | 09:23 PM
KC92F150's Avatar
KC92F150
White 97 XLT....if the trans throws a code would you get a check engine light or will the OD on/off light start blinking?
Old May 20, 2012 | 09:24 PM
calisdad's Avatar
calisdad
Yes, check for codes. If they say 'misfire in #1 cylinder' your ECU could be going out. DAMHIK. Read my posts for a real horror story. If I had it to do over I would head for a reputable dealer. Hope you have a better experience.
Old May 20, 2012 | 09:28 PM
yfz 450's Avatar
yfz 450
My check engine like or od are not lit up so does that mean there are no codes to be found
Old May 20, 2012 | 09:34 PM
White 97 xlt
There could be CM (continuous memory) codes stored and not have a check engine light..
Old May 20, 2012 | 09:42 PM
KC92F150's Avatar
KC92F150
Good to know.
When troubleshooting, I guess checking for codes whether light is on or not would be a good habit to get into.
It never dawned on me to check codes for a trans problem.
Learn something new every day.
Thanks
Old May 20, 2012 | 10:03 PM
White 97 xlt
Originally Posted by KC92F150
Good to know.
Thanks
Yes always check for codes whether or not the check engine light is on... It's cheaper to let the truck tell you whats wrong , than to just throw parts at it and hope you hit the right one!!!!!
You're not looking for trans codes specifically, any code like maybe a TPS or even a temp sensor for instance can and will affect the way an E4OD operates.
Old May 21, 2012 | 02:20 PM
UNTAMND's Avatar
UNTAMND
It seems as though the e4od is notorious for odd shifting.
It is the result of sticking actuators and servos.
First thing. Check for codes.
Second. Make sure it's at correct fluid level. Idling while hot and I prefer neutral not park.
If those first two are good. Then
Third. Put a can of seafoam in trans fluid. It's ok if it's "overfull". Drive truck for a tank of gas. 100-160 miles. You can go more. It won't hurt it
Fourth. give a filter and fluid change and flush. Getting the actuators and servos unstuck takes time. The seafoam will help break down thick buildup. The new fluid will help as well.
After 5000 miles my transmission shifts mint.
Or
Give a filter and fluid flush and then drive a while. Then buy a predator valve body and flush fluid out again (what I will do next month). It seems to correct a lot of issues these transmissions have.
Old May 21, 2012 | 02:38 PM
yfz 450's Avatar
yfz 450
thanks that is something i will look into doing
Old May 21, 2012 | 06:07 PM
KC92F150's Avatar
KC92F150
Never thought of putting Sea Foam into a trans...man I am learning alot wih this thread.
Old May 21, 2012 | 06:26 PM
444dieselrod's Avatar
444dieselrod
Sounds to me like your feeling the converter locking up. even under hard acceleration they unlock the TC inbetween gears.
Old May 21, 2012 | 09:39 PM
yfz 450's Avatar
yfz 450
Maybe I hope your rite. My other truck had 66,000 miles when the tranny went. My uncle had 2 1995 f150s and both those granny's went at 80,000 for one and about 85,000 for the other so I am so Nurvice when it comes to these things
Today I pulled the dip stick to smell the fluid and it does not smell burnt but I was not able to get it to running temp to check the level I did not drive the truck today I will try tomorrow
