1978 - 1996 Big Bronco
Help with Trans Problems
Old Sep 2, 2001 | 09:39 PM
91Bronco's Avatar
91Bronco
I have a 91 Bronco with 302 and E4OD.
When cruising on the highway at 55-60 MPH, the trans will slip out of OD ocasionally. I doesn't happen at higher speeds. Sometimes it seems as though it partially slips out of OD (ie. RPM jumps up but not as though it went down a full gear) TC slipping? At about the same time this started happening, I started getting a loud and violent thump infrequently on upshift in other gears when going easy on the gas. Shifts smooth when heavy footed.
I have religiously flushed and replace the fluid in the trans and tc every 30,000 miles. The trans has about 140,000 miles on it.
Is there any hope for this trans? Is 140,000 all I should expect from an E4OD. Where should I start looking? TC? Rebuild? Replace?
__________________
Mine - 91 Bronco
Hers - 99 Expedition
Old Sep 2, 2001 | 10:00 PM
watts_29's Avatar
watts_29
