Experience with Autogauge?
ATM-2332: AutoGage Black/Black Mechanical Engine Pressure Gauge | Auto Meter Gauges | eBuggies.com
ATM-2333: AutoGage Black/Black Electrical Engine Temperature Gauge | Auto Meter Gauges | eBuggies.com
mostly because they are relatively cheap, but Autometer typically has a good name? What do you guys think of them. The junk Summit brand gauges I bought a while back have had it. Isspro and Autometer are nice but not in my budget right now.
running oil in the cab isn't the best of idea's.you may want to consider going electric for that one.
when it comes to water temp,iv noticed under hood temps can play tricks on the electrical sending units.you may want to consider going with a mechanical for this one.
I keep looking at the Isspro but a water temp, oil psi and pyro are going to be over $500 by time I get them up here in Canada.
I had originally placed an order with Glowshift however they are giving me all kinds of grief since I have an "international" credit card....
http://www.ebay.com/itm/New-Car-Auto-Black-2-52mm-Blue-Digital-LED-F-Water-Temp-Temperature-Gauge-SL-/321288679368?pt=Motors_Car_Truck_Parts_Accessories&hash=item4ace4c2fc8&vxp=mtrI've gotten two of this type, and have been using them for a good year and a half:
My water temp gauge works flawlessly(only downside: it won't read under 104F no matter what).
My Oil Pressure gauge works mostly fine, though a solder joint failed and the 10's place digit won't light up unless I press the back.
Accuracy wise, they seem to be plenty accurate; measuring up to everything else I see.
And I figure that for $20, I'm willing to deal with some problems -- it's worth it to just buy a new one if it fails, not to worry.
And you can always use it as a temporary solution until you can replace it with a *good* one later.
Anyway, after numerous e-mails all is well. Now I just hope they work reasonably well.Thanks to everyone for the feedback.
