Sponsored by: Real Truck
Trailer Brake Hook up
Old Apr 7, 2014 | 02:20 PM
vahunter23's Avatar
vahunter23
I have recently bought a heavy equipment trailer that has a pinion hitch. I have a 08 F250 and and 03 F350. The trailer brake works with the 03 F350 with an aftermarket controller but not the F250 with the OEM controller. I have seen in the past that the OEM controllers don't pick up if there is not good contact on the ball. Is that still true? That is the only thing that I can come up with.
Old Apr 7, 2014 | 03:15 PM
jmhatchett's Avatar
jmhatchett
What type of brakes are on the trailer?? If it is a very heavy trailer it will be more than likely hydraulic. your OEM controller is for electric trailer brakes. an aftermarket controller is probably needed to allow the truck to manage a hydraulic brake system.
Unless im wrong which is possible I just remember having to do this to a Chevy Silverado work truck that towed both style trailer brakes.
Old Apr 7, 2014 | 04:13 PM
Pit Crew's Avatar
Pit Crew
Exclamation
Seems to me I had to put in a relay under the hood the first time I hooked to a trailer with electric brakes. This was a 03 f 350
Old Apr 7, 2014 | 05:49 PM
senix's Avatar
senix
It is possible that the relays are not working or even in the proper place.
Have you hooked the 08 up to any other trailers?
Have you checked for power at the rear of the truck?
Old Apr 7, 2014 | 06:27 PM
Trophy_23's Avatar
Trophy_23
With my truck it won't work with our boat trailer it has electric over hydraulic. Need to add some sort of special feedback module to the trailer from what I remember. Straight electric will work.
Old Apr 7, 2014 | 06:30 PM
ItsAllJustCastIron's Avatar
ItsAllJustCastIron
I have an 08 350 with the factory controller that works awesome. Can this be retrofitted to an 03?
Sorry to hijack but seems like the right place
Old Apr 7, 2014 | 06:51 PM
senix's Avatar
senix
No not really. You would be better with a aftermarket unit in the 03.
Old Apr 8, 2014 | 06:16 AM
vahunter23's Avatar
vahunter23
The trailer has electric brakes. I did have to replace the fuse on the 08 F250 under the hood. The 08 F250 trailer brakes work with every other trailer I have ever hooked up to, just not this one.
Old Apr 8, 2014 | 10:06 AM
Pit Crew's Avatar
Pit Crew
The relay I`m talking about was in the glove compartment from new.just had to pop it in and I was good to go.I baught the truck new so it was there.
jimmystoys
All Things Towing
Jul 31, 2023 02:20 PM
Allagash
All Things Towing
Aug 9, 2017 01:06 PM
MYTRUCKNOWRATTLES
6.7L Power Stroke Diesel
53
Nov 27, 2013 08:50 AM
brkncly
6.4L Power Stroke Diesel
Oct 25, 2012 01:18 PM
penitin30
Aug 18, 2011 07:52 PM
