BLOWN transmission - need help
Old Apr 26, 2014 | 09:02 PM
  #76
underthebridgejim's Avatar
underthebridgejim
FTE fan
Good Idea, take a breath, enjoy your favorite beverage and relax, I see on your trans. invoice they gave you a 6 month guarantee, so if your fluid is good, let them figure it out.
Old Apr 26, 2014 | 09:28 PM
  #77
bra$$monkey's Avatar
bra$$monkey
Yep. I'll let the pros take it from here
  #78
toby tough's Avatar
toby tough
You know, I always check the fluid with it warmed up and in neutral.When I warm my truck up in the winter I put it in neutral cuz the fluid flows more and it warms up quicker. Maybe it doesn't matter,just my 2.
Old Apr 26, 2014 | 09:48 PM
  #79
bra$$monkey
It flows more in neutral?
The trans had some kind of shift kit before the rebuild. It would hit 2nd gear so hard it chirped the fat back tires.
I wonder if there is a problem with the valve body because of that.
Old Apr 26, 2014 | 10:27 PM
  #80
toby tough's Avatar
toby tough
Well I don't know if it flows more so to speak, but I think it just goes thru more passages within the valve body and wotnot. Sure makes a difference when it's -20 out. Not sure about the shift kit/valve body thing.
Old Apr 27, 2014 | 12:33 AM
  #81
seaves46's Avatar
seaves46
It doesn't make any difference with fluid flow in neutral or park .
It's just safer to do it in park as you can't get run over by your own vehicle
I think you will find with a bit more fluid your trans will be just fine .
Also if you want to ease the harsh shifts a bit you should be able to adjust your vacuum modulator .
Old Apr 27, 2014 | 10:59 AM
  #82
dmack91's Avatar
dmack91
I think the tc would take more than one quart. How many quarts total did you put in the trans originally? When first draining and refilling mine (it had been sitting for over two years in the PO's yard and I had no idea what condition it was in), I checked the interweb and found capacities from 5-9 quarts iirc.
When I did mine, I put in around 5 quarts, and nothing happened. I ended up adding another 3-4 quarts and everything worked fine.
Old Apr 27, 2014 | 12:11 PM
  #83
bra$$monkey
SWEET BABY JESUS WITH A PARTY SHIRT ON!!!
I warmed it up on flat ground and there was no fluid on the stick. I added 2 more quarts and BINGO!!!
the truck runs perfect! It doesn't hesitate, it doesn't clunk & it shifts smooth but firm no slamming into 2nd!
The problem I had with the rear pushing forward jamming the trans forward causing it to shift into second is fixed!
Oh thank you everyone for your help. The purple people Eater is BACK ON THE ROAD!!!
HAHAHAHAHAHAHAHAHAHAHHAHA
Old Apr 27, 2014 | 02:14 PM
  #84
underthebridgejim
FTE fan
Rite on !!!!!!!! Sometimes these super frustrating situations take on a life of there own, and at least in my case, the more trouble I find, the more frustrated I get, and the more frustrated I get the more trouble I have and so on, and so on. But it is always and I do mean always, the folks here on FTE that save the day. Ok sorry this kind of took me back to my own past experiences, but Im so happy your problems have been resolved and your back on the road. Congratulations, enjoy.
Old Apr 27, 2014 | 04:08 PM
  #85
dmack91's Avatar
dmack91
Congrats! Time to just have fun driving again.
Old Apr 27, 2014 | 04:43 PM
  #86
seaves46's Avatar
seaves46
Well done , hopefully now you will have a trouble free run .
I wish mine was back on the road , but it will be another 12 months for me .
ChuckRob
19
Sep 25, 2014 04:52 PM
kentruckf100
Apr 3, 2011 11:20 AM
71dusterdan
Mar 18, 2008 09:15 PM
1low50
Sep 28, 2007 05:44 PM
notsoswwuyd
Mar 31, 2005 12:29 AM
