What is this engine?
Old Mar 24, 2014 | 04:28 PM
SuperDuty93's Avatar
SuperDuty93
Anyone have any idea what this engine is? Lady told me she thought it was a Lincoln block from like a 1960 something but im almost positive its not a a 430 long block.
Old Mar 24, 2014 | 05:43 PM
mgargiullo's Avatar
mgargiullo
Hard to tell from the picture. Best bet is to grab the casting number from the block. If you can't grab that, grab the casting number from one of the heads, that will at least tell you the block series. Does that timing cover go with that block? I ask because it reminds me of an Oldsmobile.
Old Mar 24, 2014 | 05:45 PM
mgargiullo's Avatar
mgargiullo
Just a guess from the block shape, size and timing cover on the motor... I'd guess it's an FE series block.
Old Mar 24, 2014 | 05:55 PM
SuperDuty93
I think its a 317 Y block. It isn't a 360 390 (352 based) FE block at least
Old Mar 24, 2014 | 06:03 PM
mgargiullo's Avatar
mgargiullo
Yeah I can see that. Maybe you get lucky and it's the 368 Y block. She selling it?
Old Mar 24, 2014 | 06:06 PM
finn's Avatar
finn
It's not an FE or FT. Both the FE and FT have valve covers that bridge the intake manifold, i.e. the upper valve cover rail is actually part of the intake manifold.
The 2.8, 2.9, and 4.0 Cologne engines are designed like that also.
It may be the earlier Lincoln engine or the F600+ truck engine based on the Lincoln engine. The truck version was available until, I think 1964.
The 430 Lincoln engine would have an oddball block like the 348-409 Chevrolet where the deck isn't perpendicular to the bores, with flat bottom heads (no combustion chambers in the head): The chamber was effectively in the Bore. I think the later "Super Duty" gas engines were like that too.
If the head surface is perpendicular to the bores, then early Lincoln / Ford truck. If the head surface id at an angle, then Superduty or Lincoln / Merc pass car (2 different families)
Old Mar 24, 2014 | 06:21 PM
SuperDuty93
I know its not a Fe one but ill ask her to get me casting numbers. And we can go from there.
Old Mar 27, 2014 | 10:19 PM
truckpastor's Avatar
truckpastor
Any luck finding out what this engine is?
Old Mar 28, 2014 | 04:59 PM
cobraguy's Avatar
cobraguy
Doesn't look right for a Y block. The exhaust manifold bolts and port spacing are wrong. Is it even a Ford? With the funky green my guess is a International Harvester
Old Mar 29, 2014 | 03:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Lincoln derived Y blocks: Left upper: 1952 279/317 / Right: 1953/55 279/317 / Left lower: 1956/63 302/332.
The pictured water pump does not match the truck parts catalog pics for any of these engines. So this is probably a 1952/55 Lincoln 317.
Old Mar 29, 2014 | 03:26 AM
SuperDuty93
Interesting. Thanks number dummy. Lady wants $300 for it. Not sure its worth that
66BlueOval
15
May 9, 2025 03:58 PM
1976rustbucket
Apr 25, 2008 11:57 AM
lifted77f250
Oct 27, 2007 09:10 PM
71 Sport Custom
Oct 23, 2005 01:22 PM
sfc11b
13
Jul 2, 2005 11:20 AM
