Block ID Problem
Old Jul 1, 2005 | 01:39 PM
sfc11b's Avatar
sfc11b
Block ID Problem
C3AE-6015-H is on the front passenger side of block. Think it is a 63 motor but can not find anything on the H! Bn all over the Web and found others with the same block. No one knows what it is for sure. I'm guessing 360 block. Intake is C3AE-9425-B. Any help?
Chris
Old Jul 1, 2005 | 01:49 PM
Mike G's Avatar
Mike G
Does it have a large "HP" on the block below the casting The 360 was not put into production until 68, and then it is the same block as the 390... I would have to guess you are looking at a 352, but you need to measure the cylinder bore, that will tell you what's up.
--Mike
Old Jul 1, 2005 | 01:53 PM
bshackelford711's Avatar
bshackelford711
Chris
I did not see anything in my books for the C3AE-6015-H block number.
and i dont have anything on intakes
maybe someone could send me some
If i had to guess with that year block i would look at it being a 352 or a 390 before i would a 360.
What type of vehicle is or was it in?
Old Jul 1, 2005 | 02:04 PM
sfc11b's Avatar
sfc11b
Its in a 74 F-100 4x4. I found the truck in a pine forest for $1K. I know its an FE block. Has 4BBL manifold. I changed some gaskets on it, and they looked like original cork. No sealant anywhere on them. I have problems getting small things like a Thermostat. The one in the motor was big. Had to ask for one from a 64 352CID to get the right size.
Old Jul 1, 2005 | 02:07 PM
bshackelford711
If it is in a 74 F-100 it is not going to be the original motor. You can measure the stroke to get a better idea to know what you have got.
Old Jul 1, 2005 | 04:08 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Ok the C3AE-6015-H is a service replacement block for the police car 390's. This block is the service replacement for the C3AE-E 390 block. On the intake you sure it's a B and not E? I have a C3AE-E 1x4 aluminum lowriser and a C3AE-K 2x4 aluminum lowriser. If it's a B I'll dig deeper and find out. G.
Old Jul 1, 2005 | 05:07 PM
sfc11b's Avatar
sfc11b
Just checked again on intake. 4BBL manifold C3AE-B. Thanks for the help!
Old Jul 1, 2005 | 05:30 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Found it. Listed as a 63 390 intake. I'm assuming it's iron as it's not spec'ed as aluminum. Hey what is the number after the 6090 opposite the C3AE on the heads? G.
Old Jul 1, 2005 | 05:32 PM
sfc11b's Avatar
sfc11b
OK, just saw a 390 intake on e-bay with same #'s C3AE-9425-B. It is billed as a Police Interceptor Manifold 1963. Do you know if this motor has hydro or solid lifters by the book?
Thanks
Old Jul 1, 2005 | 06:07 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
It lists the block as a hyd lifter block but also has a note that lifter galleys to be blocked for solid cam PI applications. From what I understand about that casting it was used in service block applications for both hyd and solid lifter cams. Kind of a dual purpose block if you will. But it listed as the 390 PI engine block replacement for the C3-E. With the PI intake I'd have to safely say the 390 came out of an old cop car before finding it's home in your truck.
Old Jul 1, 2005 | 06:42 PM
sfc11b's Avatar
sfc11b
Thanks,
Will pull the valve cover off tomorrow to check rest of head number. Only shows first 4 letters on outside right?
Old Jul 1, 2005 | 07:04 PM
sfc11b's Avatar
sfc11b
OK got the last letter for heads. Its C3AE-C. Anything you could tell me about these would be great
Old Jul 2, 2005 | 05:27 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The C3-C heads came in two versions. First listing are late 406 heads with valve spring seat cups and a larger 1.66 exaust valve. Head cc's listed as 56.4-61. Second the same heads were used on many 390's without the seat cups and smaller exaust 1.55 valves. CC's are the same at 56.4-61. Both are a 63 listing.
G.
Old Jul 2, 2005 | 11:20 AM
sfc11b's Avatar
sfc11b
Thanks for all the help!
DbleJ2010
Jul 13, 2010 05:14 PM
killaz
Mar 14, 2008 10:54 PM
tn.countrygirl
General Automotive Discussion
15
Jul 13, 2007 01:48 PM
chris h
2004 - 2008 F150
Jan 17, 2006 07:12 PM
oldiron
Aug 26, 2002 08:16 PM
