FE Block Numbers
Old Mar 22, 2004 | 01:23 PM
66BlueOval's Avatar
66BlueOval
Question FE Block Numbers
Can someone decode the block number on my motor. It is C8MEA.
Thanks
Old Mar 22, 2004 | 02:04 PM
fordeverpower's Avatar
fordeverpower
its a 1968 block
Old Mar 22, 2004 | 09:51 PM
baddad457's Avatar
baddad457
Not necessarly a 68 block. Only the date code will tell you that. A C8ME could have been cast in 69 or 70 too. My book list's it as a 428CJ block, but these books have been known to be wrong too.
Old Mar 22, 2004 | 09:58 PM
fordman428's Avatar
fordman428
1968 428cj block out of a car. atleast thats what the book says
Old Mar 22, 2004 | 10:19 PM
fordeverpower
they are junk! you should send it to me and i get you a 390 instead!
Old Mar 22, 2004 | 10:43 PM
rusty70f100's Avatar
rusty70f100
It's either a 428 block, or a 330HD block, or a 361 / 391 FT block. Casting molds were probably made in 1968 for Mercury applications, but it could have been cast later than that for a variety of uses. Since it shares numbers with FT blocks, it's probably a good strong thick cylinder wall block.
Old Jan 2, 2013 | 10:00 PM
Fomoko1's Avatar
Fomoko1
I know that this is a very old thread but..... can this be safely bored out to a 428 bore without sonic checking?
Old Jan 2, 2013 | 10:08 PM
85e150's Avatar
85e150
"This"???? If "this" is a 390 block, no, you should sonic check it.
Old Jan 2, 2013 | 10:43 PM
Fomoko1's Avatar
Fomoko1
I`m referring to specifically a 360 truck block like a C8ME, I know that the 390 blocks need to be checked. Put a different way are all the 360/390 blocks from cars and light trucks all the same for cylinder wall thickness?
Old Jan 3, 2013 | 07:36 AM
baddad457's Avatar
baddad457
360 -390 are one and the same block. Both had the same bore size: 4.05 the difference in displacement was in the stroke. C8ME isn't a truck block. It's the std car casting. Be that as it may, cylinder wall thickness is a "hit or miss" deal when it comes to FE blocks. Some got thicker cylinders, some didn't. Core shift plays a big role in determining wall thickness too, you can have a thick walled block, but if any one (or more) of the cores shifted in casting, that in itself can render it with thin walls when adding in an overbore.
Old May 8, 2025 | 12:28 PM
Old Guy F-250's Avatar
Old Guy F-250
Yea OLD THREAD for sure
BUT, I have an opportunity to buy a Ford BB and the guy says it's a 428CJ engine.
I have not put eyes on it yet as it is bout 3 hrs away.
I did ask a few questions and it is a C8ME-A block
When ask about the intake I was told it had a 2 barrel intake.??
Thought all CJ's were 4 BBL.
After doin a lot of serching on inerweb, looks like that number could also be a 68 390, or several other FE;s.
Finally, my question, What on the externals if any will distinguish this as a 438 CJ if any.
Thank you, Alex
Old May 9, 2025 | 09:42 AM
DaveMcLain's Avatar
DaveMcLain
428;s all have a flexplate or flywheel with a weight. SCJ 428's also have a weight on the balancer spacer very similar to the '79 and up 460 engines.
Old May 9, 2025 | 10:09 AM
stryder's Avatar
stryder
Thank you, Alex
All the information you'll ever need to fully identify a 428CJ motor: https://www.428cobrajet.org/id-main
Old May 9, 2025 | 10:34 AM
Old Guy F-250
I was really curious bout the 2bbl manifold...on a 428 CJ engine.
Thank you guys for the replies.
Alex
Old May 9, 2025 | 11:46 AM
charlie g's Avatar
charlie g
FTE Community Team
https://www.mustangtek.com/block/Block.html shows that number for a 428 which was not made with a 2 barrel, that intake to me spells issues
