big block motor mount location
Old Mar 16, 2014 | 09:21 AM
dwelch7's Avatar
dwelch7
I am looking for info on where to locate the motor mounts for a big block (460) on my frame. The body is off (at paint), and I'm trying to get the frame set up. I'm using separate side-mount engine mounts, and if anyone has the same setup, any info would be extremely helpful. I just need a measurement from a known point on the frame to where the mounts are attached. Thanks, Dave
Old May 29, 2014 | 08:38 AM
Barry Whiting's Avatar
Barry Whiting
DWelch,
Did you ever get any help on your engine mounting issue?? I am currently struggling with the same thing and our only difference is that I am using a tubular x member that I purchased from speeway. My question is where to mount the x member so that exhaust clears. I have some pictures that I found of your installation method if your interested.
Old May 29, 2014 | 09:09 AM
dwelch7's Avatar
dwelch7
motor mounts
I never did get any replies on my thread - any information or pics that you might know about would be helpful.
Thanks,
Dave
Old May 29, 2014 | 10:16 AM
jniolon's Avatar
jniolon
old and in the way
hey guys
tied up right now but later today I'll get home and get some measurements. I'm running a 460 with a Mustang II ifs.... that may or may not make a difference with your setup... also my radiator setup is different than stock... but my engine mounts put the rear of my valve covers about 1/2" from the firewall... back later
John
Old May 29, 2014 | 10:51 AM
dwelch7's Avatar
dwelch7
thanks
cool - my setup is a mustang II also - thanks for the help
Dave
Old May 29, 2014 | 12:17 PM
Barry Whiting
Dave,
My email is abwhiting@hotmail.com and if you send me an email I will send what I have found. I cannot post those pictures because I only have them in a word document. They might not be of much help because they are for my application, original straight axle with stock suspension. But, they clearly show where to mount the motor with individual mounts on each side and Sanderson headers.
Old May 29, 2014 | 03:40 PM
jniolon's Avatar
jniolon
old and in the way
here you go Dave...
from the front edge of the front cab mount to the center line of my engine mount is 22-3/4"
that's with a 460 over a MII IFS
Old May 30, 2014 | 05:27 AM
Barry Whiting
John,
Thanks for your last post and it should help me as well as I also needed measurements from a known point. The pictures that I had collected allowed me to see "about" where to place my motor mounts.
Old May 30, 2014 | 09:15 AM
jniolon's Avatar
jniolon
old and in the way
Barry... I'm running an electric fan and a stock water pump... if you're running mech fan it might make a difference...
the motor mounts just about center up the crossmember for the ifs.
john
Old May 30, 2014 | 09:36 AM
Barry Whiting
John,
My experience with electric fans is not good but maybe that was because of the car and the application. This is my second build and my first, '69 Mach 1 named Scarlet, had over heating problems from the start and I even had the biggest aluminum radiator I could buy. The only solution that worked was a mechanical fan AND an electric fan used as a pusher. Now she runs cool as a cucumber, even on 100 F days. So I will absolutley use a mechanical fan and I won't put an electric on unless I need to or if space is a problem with a mechanical. I have been around these old Fords all my life and my experience tells me that you could not get by with a flathead and an electric fan but I have seen people do it successfully. By the way, this is the very truck I learned to drive on almost 40 years ago and I was lucky enough to buy it from my Dad before he passed away in 2010.
Old Jun 30, 2016 | 05:29 AM
56exp's Avatar
56exp
Barry, I know this is an old post,I am putting 460 over stock suspension and just wondering how it is holding up??? I hope your project is coming along, its cool it was your dads truck.
Old Jun 30, 2016 | 07:17 AM
Barry Whiting
460 Motor Mounts
Hi 56,
We went into a bit of a hibernation but are back at it now. I have not started the motor build as I have been addressing strength of the frame first. I just recently build a K brace and added the original front motor mounts back in for support. Relocated my rear lower shock mounts as I am running a Ford 9". For a bit of added strength I am going with Monroe coil over shocks front and rear to handle the weight of the motor and I intend to pull my show car on a trailer. Getting ready to add a front and rear sway bar for corning and then after that I will finish coating my frame. I favor a product called POR 15 that I have had good luck with. Can't make up my mind if I want to get on the body work next and put the body back together (except for the doghouse) or do the motor build. I suspect that I will do the body work as I already have all the parts I will need and that is the cheaper route for now.
Good luck to you and I hope to hear from you. I it funny that I just got email notification that my post had a reply after over a year.
Stan Balafas
36
Feb 22, 2017 03:53 PM
lowtrkn2k
Aug 27, 2012 03:59 PM
shortbed1
Nov 30, 2006 04:56 PM
BigBlockFord3
17
Nov 9, 2004 10:22 PM
nightravin13
Jan 28, 2004 05:01 AM
