Need help with block trace for motor mounts!!!
Old Jan 27, 2004 | 08:08 PM
nightravin13's Avatar
nightravin13
Unhappy Need help with block trace for motor mounts!!!
Hey guys....i am having an extremly hard time figureing out what vehicle my engine came from.
I'm trying to get motor mounts but can't seem to find the right set. (It's the only thing stopping my engine install.)
The block number i got off it is D1VE 6015 A2E
if anyone can find out for me or recommend a good website for me to look at....please let me know....please.
this is driving me crazy.
the mounts that came off are a three hole mount.
Old Jan 27, 2004 | 08:42 PM
nightravin13
i found this after a long search..... 71 lincoln
http://www.ac427.com/html/cobra_17.shtml
can someone verify?
Old Jan 27, 2004 | 08:52 PM
Wyoming10's Avatar
Wyoming10
My book says a 71 Lincoln 460 engine also....What are you putting it in? I think the blocks are the same (engine mount wise)for each engine family you should be able to get the mounts for the application you are putting it in.
Old Jan 27, 2004 | 08:53 PM
fordpilot's Avatar
fordpilot
ya nighttrain... i have or will be having the same problem and plan on having them fabricated.. it doesn't look like a big deal.
Old Jan 27, 2004 | 10:42 PM
Ford79's Avatar
Ford79
The block casting number you have was used from 71 until at least 78, if not later, in everything from Lincolns to 2wd trucks. Try www.landlproducts.com for mounts to swap the engine into your truck.
Old Jan 28, 2004 | 05:01 AM
nightravin13
thanx for the help guys.
