Need some help with this puzzle
My brother is all about them, and he actually has a super duty parts truck that he said I can have anything I need off it. It has a factory lift block in the back that is about twice as big as mine, and the front suspension looks the same as mine.
Will I benefit at all from the front?
And should I swap the block only in the back, or the springs as well?
I'm trying to fit some 35's under it. So I'm fairly certain that I have the rear covered, but is there anything I can do about the front with the parts I have? Or should I get a shackle hanger for the front to lift it up?
And would it be a really bad idea to put the rear block from my ex on the front axle to lift it? Or would that not even work?
Just trying to think outside the box....
Thanks for the help!
Best thing you can do is get the numbers off of the front leaf springs and post it here to try to determine what they are.
Never use any type of block in the front!
The superduty rear block is compatible with the excursion and will net you 1.5 inches of lift in the rear. You will need new u-bolts.
Shackles are a great cheap way to accomplish a mild front lift, but first let's figure out what's on the superduty so we can estimate the lift you can get out of them on your Ex.
As far as 35's I don't know what back spacing you would need, some will will chime in I'm sure. I have a 5inch lift and had to trim a little so they wouldn't rub.
So if I'm only getting 1.5" of lift in the rear from the blocks, is it looking like I'm going to need some other source of lift to clear the 35s?
If so I'll just get a 4-5" lift and not have to fiddle around with swapping all the parts from truck to truck.
And LivingLarge has it right, don't ever run blocks on the front axle!
I couldn't find anything on the leaf springs, and it doesn't have a drivers door. I'll look again for the sticker on the chassis, but I didn't see anything
Do you know where the lettering would be on the springs?
Also, should I swap just the rear block, or the springs too?
Thanks again for y'all's help!!
Do you know where the lettering would be on the springs? Sometimes we can decode the springs from the numbers stamped into the steel, sometimes not.........They really aren't part numbers, just some kind of crazy engineering number from ford.
Also, should I swap just the rear block, or the springs too? Typically the truck rear springs are an improvement over the factory EX rears and there are a few tricks to mod them for different desired goals, such as just wanting a lift, fixing a wandering EX, towing heavy or carrying a lot of interior weght. I would suggest that you read this excellent post from the Ex tech folder at the top of this forum https://www.ford-trucks.com/forums/7...ml#post6722938 This thread and others in the tech folder will make for good reading for anyone considering a spring swap. I know it helped me make my decisions when planning my swap.
EDIT: Dangit, it wouldn't let me but I tried. I apparently have to spread the reps around a bit first.
Stop, You're making me blush!
RPN1348"
I dont know what any of that means. But it is a 1999 F350. Im not sure if its an early or late 99. There isn't much left, just the interior, and suspension pretty much. no engine or trans. So im not sure what else i can identify it with.
I'm just trying to lift it up a little bit. i already have 35s on there and it fits fine, id just like to make it sit higher and level.
Thanks again for yall's help. Its greatly appreciated
RPN1348"
Unfortunately those numbers don't match up with anything I have on my lists. Do you know what motor the truck had in it? The deezles are heavier than the V-8s and V-10s so their springs were heavier. Almost any SD spring will be an improvement over the Ex stock springs, our EXs came from the factory riding about 2" lower than the same year SuperDuties did. And if the parts truck was an oil burner and your EX is a gasser the improvement would be even better. Did you read through the link to the spring swap thread from the Tech Folder I posted earlier? You really should, it has a lot of excellent info about this topic in it.
As I mentioned earlier your Ford dealer may be able to give you the spring codes from the VIN, I'm not positive how far back they have the ability to lookup such details.
The factory Ex springs are far from great and plenty of us EX folks have upgraded our rides with various combinations of the truck springs. It's a popular mod to swap in a set of the truck rear springs with a couple of the EX's leaves added to the pack, or use the taller lift block or a combination of both, like I have. Most truck front springs are better than what Ford gave the EXs and they too can be modded by addition of an extra leaf or two scavanged from either the truck or EX spring packs, my front truck springs are also modded in this way.
It is a diesel, so I guess I can just add the spring to my spring pack to lift it a bit up front. My rear is perfectly fine and doesn't even come close, the front is what I have a little scrubbing with.
And one more question, should my truck have a factory steering stabilizer?
If you do the fronts and then find it looks a bit droopy in the rear that can be easily fixxed with the taller SD rear block.
Yes, your Ex should have a factory steering stabilizer.
Mine didn't have one, I actually just installed one yesterday and it helped some of the wobble I was getting.
I'll post up some pics once I swap the front springs.
Thanks again for the help! I really appreciate it!
