Offroad & 4x4
lift help
Old Apr 12, 2012 | 10:53 PM
swampsuperduty's Avatar
swampsuperduty
lift help
What's the cheapest/easiest way to lift a 4x4 f250 with leaf springs all the way around? I was thinking 3 inch blocks in the front and two in the back to level it up, but am I going to have modify anything? Any advice/ideas?
Old Apr 13, 2012 | 12:30 AM
86sixbanger's Avatar
86sixbanger
Sounds good. If you want more lift just stack more blocks front n rear.
Old Apr 13, 2012 | 01:36 AM
ArrizX's Avatar
ArrizX
Do not use blocks in the front.
Shackles in the front, blocks rear.
Old Apr 13, 2012 | 01:38 AM
khadma's Avatar
khadma
Carpenter Local 745
Front lift blocks?
Is this truck driven on the road too?
Old Apr 13, 2012 | 06:34 AM
tjc transport's Avatar
tjc transport
i ain't rite
front lift blocks are illegal in most states for on road use.
do it rite, or don't do it at all.
Old Apr 13, 2012 | 07:55 AM
alpha/omega's Avatar
alpha/omega
:shakeshead:
Do not put blocks in the front and do not stack blocks in the rear. Also, shackles only in the front will cause your caster/pinion angle to get all fubar.
Assuming you are talking about a Superduty based on your username:
The "correct" way to do this on the cheap would be new drop hangers for the front of the leaf springs and add a leafs in the rear. This is only good for 2-3" of lift in most cases.
What size tires do you want to put on the truck?
Old Apr 14, 2012 | 10:40 AM
mark a.'s Avatar
mark a.
Make sure you use treated 4x4's. If you need to stack them use the galvanized coated drywall screws to secure them together.
Old Apr 14, 2012 | 12:59 PM
khadma's Avatar
khadma
Carpenter Local 745
Alternating the grain direction will also add tons of strength.
He posted the same question in another forum, and he plans to do the lift
Properly. Add a leaf front and only one block on the rear.
Old Apr 14, 2012 | 01:04 PM
ToMang07's Avatar
ToMang07
OP: Just a thought, depending on what you want for a lift, keep in mind not all lifts are equal, especially when comparing between a 250/350.
I know a guy who just put a 4" Rough Country Lift on his 250.... it only sits 1" higher than my leveled 350. (I purchased a 2" Mini-Spring pack and X-Code Springs.)
That's with both of us having 35" tires, too.
And as others before me said, NO BLOCKS on the front end.
Old Apr 14, 2012 | 09:07 PM
alpha/omega
Guy who uses blue text and oddball font: My 04 F250 fits 315/75/16s with zero lift.
Old Apr 14, 2012 | 09:43 PM
ToMang07's Avatar
ToMang07
Guy who feels it necessary to address other people indirectly and not just use the "quote" button:
Good for you. The guy with the 250 was running 35s before the lift. My point has nothing to do with tires, it was to point out that a 4" lift won't necessarily lift the truck 4"
Old Apr 15, 2012 | 08:01 AM
77mud's Avatar
77mud
when you get it lifted get you a set of thornbirds,,, Best tire ever made!!
Old Apr 15, 2012 | 11:59 PM
86sixbanger
dammit I was just gonna throw that in, you read my mind. ****ing t birds, theres like a gajillion sets on my local craigslist right now as I'm shopping for tsl's or ltb's.....guess lotsa people musta learned they suck the hard way lately...
Old Apr 16, 2012 | 05:45 PM
alpha/omega
You answered your own question...
2-2.5" level kit + x code springs will net you 3"+ so it stands to reason that his truck with 4" of lift sits exactly 1" higher than your truck and the advertised lift is exactly right.
Old Apr 16, 2012 | 05:57 PM
ToMang07's Avatar
ToMang07
There was no question. Glad to see you found the quote button.
The leveling kit I used added 2", and the springs added 2"
The difference between a 250 and 350 rear block is 2".... so it only lifted his rear end 3"
Again.... my point was not all lifts are going to lift the same. What works for one person might not get the same results for the other.
