Sponsored by: Kumho
Rear lift blocks?
Old Feb 8, 2006 | 04:16 PM
nantruckit's Avatar
nantruckit
Rear lift blocks?
I'm looking to lift my Excursion a little, and I found a lift that I like by Fabtech. It's the 3.5"hanger lift. The only thing is it says I'll need 2"blocks for the back that aren't included. Where would I get those? Thanks in advance.
Old Feb 8, 2006 | 05:22 PM
ivanribic's Avatar
ivanribic
Try www.broncograveyard.com or www.ntwonline.com. You can also find them on ebay frequently. They don't need to be specific to the Excursion, just a generic 2" block will work. Check if they come with u-bolts or not. If not then you will need to get extended u-bolts for them or have a set made.
Old Feb 15, 2006 | 09:08 PM
vman's Avatar
vman
Just make sure you get a set that is tapered and is the same width as your leaf springs.
Old Feb 16, 2006 | 05:24 PM
nick88f150's Avatar
nick88f150
I got mine at Advance Auto parts
