What is this?
Old Mar 15, 2014 | 07:34 PM
mont974x4's Avatar
mont974x4
What is this?
There is a white hard plastic (? maybe ceramic ?) piece bolted to the drivers side of the firewall. There's 2 wires connected to it.
What is it? Mine broke into 2 pieces and it has some sort of coiled wire in it. I am assuming its a resistor of some sort.
Thanks
Old Mar 15, 2014 | 07:43 PM
mgargiullo's Avatar
mgargiullo
Without a picture it's hard to say for sure. However, there is a ceramic resister that looks as you describe, but is usually attached to the coil not the firewall.
Old Mar 15, 2014 | 07:56 PM
mont974x4's Avatar
mont974x4
Here's a pic.
Old Mar 15, 2014 | 08:09 PM
Tedster9's Avatar
Tedster9
Gotta be for the coil? Or heater blower.. Or, was the truck modded from 6 to 12 volts? Can't be if truck is after 53, hm.
Sent from my iPhone using IB AutoGroup
Old Mar 15, 2014 | 08:12 PM
mont974x4's Avatar
mont974x4
The truck is a '58 and is 12 Volt. I don't know if it was 12V stock or not.
Old Mar 15, 2014 | 08:19 PM
Danleig's Avatar
Danleig
Ignition resistor to the coil, helps the points last longer in the distributor by reducing the voltage to them.
Old Mar 15, 2014 | 08:33 PM
mont974x4's Avatar
mont974x4
Thanks.
kevinmcc2
Jun 22, 2018 11:06 PM
rasmuspa
Jun 27, 2016 01:36 PM
Uni Moe
Apr 17, 2014 07:37 PM
Nohaj1
Oct 26, 2005 11:15 PM
MARC
Mar 4, 2005 05:51 PM
