7 Pin Trailer Plug Retention?
Old Mar 12, 2014 | 07:45 PM
Smokeispower's Avatar
Smokeispower
I've searched here and other sites, not a lot of info except it seems that some people will use twist ties, Velcro strips and/or small bungee cords to hold the trailer plug in the receptacle on the truck.
I NEVER had an issue with my 2011 SD, even at -20 when the wiring was stiff as a ..... well, you know. Now I've traded for a 2012 SD, and the plug just drops out whenever it feels like it. Definitely turning puts stress on it, but it just never seems to seat properly, just barely touches the contacts when the lip on the lid is positioned correctly.
So what do you guys do? Was I just lucky with the 2011? I bought a new socket from the dealer, and it is the same. Sloppy fit. So am I now bungee cord boy to keep the plug in? I'm off to the trailer shop tomorrow to see if there's something on their shelves that fits better.
Any ideas? I'm not thrilled with the thought of the plug dropping out and losing the brakes. With my luck it would be on a 3 mile downhill.......
Old Mar 12, 2014 | 08:38 PM
crop harvester's Avatar
crop harvester
we leased five 2012 trucks & none of them had trailor plug problems, & they all towed trailers,so something is wrong with one or the other halves on your 7 pin plug.good luck.
Old Mar 12, 2014 | 08:43 PM
senix's Avatar
senix
On the receptacle of everyone that I have owned the lid has a catch that is suppose to hold the plug in.
Your cover for the plug does not do this?
Old Mar 12, 2014 | 08:49 PM
RV_Tech's Avatar
RV_Tech
I agree with the above. something is wrong here with one component or the other. this is not a normal problem.
Steve
Old Mar 12, 2014 | 09:05 PM
nojoke327's Avatar
nojoke327
Definitely not normal. I actually broke all the clips holding the female side on the truck because it is such a tight fit
Old Mar 13, 2014 | 05:25 AM
Gearitis's Avatar
Gearitis
I have a plug in the bed and under the bumper and both are very tight and lock via the lid on the male portion of the plug. In fact you almost need something to "persuade" it to lock into place. Something definitely missing.
Old Mar 13, 2014 | 06:09 AM
Smokeispower
I agree. The lock is there on the lid, but the fit of the plug into the receptacle is sloppy, and it does not feel like it engages properly. I'm taking the new socket I bought for the truck to our local trailer dealer to see what's up. I can compare it to the same brand trailer sitting new in his lot and also his replacement plugs. Glad to hear that it's not normal, because that means it can be fixed.
Old Mar 13, 2014 | 11:03 AM
r2millers's Avatar
r2millers
There's a set screw on the plug that holds the plug assembly to the casing properly. You might check to see that this assembly isn't moving back into the casing with pressure, thus not allowing it to plug in completely.
Old Mar 13, 2014 | 02:19 PM
Smokeispower
Thanks for the tip on the setscrew. I know what you're referring to but this trailer side plug is one piece molded. It looks like a combination of slightly smaller size (length and OD) of the plug itself and very low temperatures making the wire much stiffer have caused this problem. Not being able to move to warmer climates, I picked up a Reese replacement plug, and it fits properly at -15, no retention issues. So to go one step better, I've ordered a complete replacement cable with plug from Curt, now that I know it's the trailer side that's having issues.
EZ Hauler, you sold me a nice trailer, too bad you cheaped out on the wiring!
Thanks for your help guys, real opinions instead of that sheepish stuff at rv.net
Old Mar 14, 2014 | 11:24 AM
r2millers's Avatar
r2millers
Just make sure when you wire up the new harness, you wire it up "mirrored" to the receptacle to ensure proper contact to contact.
19rubyrower
Mar 29, 2019 08:41 PM
freesoul
Feb 11, 2012 06:58 PM
DaveandJennyP
Aug 30, 2009 09:30 AM
preppypyro
Aug 7, 2008 03:07 PM
jmcder53
All Things Towing
Jun 14, 2008 06:57 PM
