4 prong plug is different.
Old Jun 14, 2008 | 02:43 AM
jmcder53's Avatar
jmcder53
can't seem to get the plug from a trailer to plug in to the ford installed 4 prong plug, both on a 2000 and a 2007. they plastic is thicker and has a rubber molded cover that goes around it. what is the deal? never had any issued with what was on my ranger.
Old Jun 14, 2008 | 03:16 AM
GregsSD's Avatar
GregsSD
It's probably just because they are different brands and are made just a little different.
Try spraying them with WD-40 or silicone spray, this might make it easier to get them together.
If worse comes to worse and they won't go together then you should just buy a new plug for your trailer that is not the same brand as the one already on it and it should plug in easier.
Old Jun 14, 2008 | 02:04 PM
Steina's Avatar
Steina
CO River Rat
Using a razor blade to get rid of the interfering material will do the trick.
Steve
Old Jun 14, 2008 | 03:45 PM
miker67's Avatar
miker67
Ford, in its infinite wisdom did this. 90% of the aftermarket plugs will not plug in properly. As stated earlier, use a razorknife and trim around the plug on the truck side, and you will not have any more problems with any plug, on any trailer/
Old Jun 14, 2008 | 05:58 PM
jmcder53's Avatar
jmcder53
thanks for the info, and miker67, your avatar rocks.
Old Jun 14, 2008 | 06:57 PM
jake00's Avatar
jake00
I've had to trim a few plugs
