Drivers door moves allot while driving
Old Mar 10, 2014 | 02:12 PM
Htarpley80's Avatar
Htarpley80
My 2007 F150 Crew Cab Drivers door moves in and out wile driving, also it sounds like I can hear the outside air coming in. I checked the rubber weatherstrips and all seem to be in tact. Can someione tell me if this is a common problem, or how to fix. Thank you!
Old Mar 10, 2014 | 06:23 PM
danorules's Avatar
danorules
The door strike can be adjusted to make the door fit more closely
Old Mar 11, 2014 | 07:16 AM
Htarpley80's Avatar
Htarpley80
RE:
Do I just loosen the 3 torx screws and move, or will it be jammed, also do you know what size they are being that I do not own a set of torx drivers. Thank you!
Old Mar 11, 2014 | 01:31 PM
1saxman's Avatar
1saxman
It usually is a small adjustment, maybe 1/16". Scribe a line or make a mark where it is now. Loosen the fasteners slightly and tap the assembly 'IN' toward the cabin. Tighten it back up and try that. I have the 4 door standard cab that they made for a few years, and if I don't forcefully close the driver's side rear door, it will shake on bumps. I've just never got around to adjusting it. It is a handy space behind the seat and I use it all the time.
Old Mar 11, 2014 | 01:42 PM
Htarpley80's Avatar
Htarpley80
Thank you!
Old Mar 12, 2014 | 11:08 PM
442w30's Avatar
442w30
My 08 Extra cab has the same " loose rattle with wind noise" I tried to adjust but the Torks self center and bring strike back to original location :/. Any thoughts?
Old Mar 13, 2014 | 12:26 AM
EBC-150's Avatar
EBC-150
You are loosening them too much. Also use a pry bar in the striker loop to help hold it, as it will want to twist on you when tightening the torx screws.
Old Mar 13, 2014 | 09:34 AM
Htarpley80's Avatar
Htarpley80
Fixed mine. Thanks!
Old Mar 13, 2014 | 07:20 PM
1saxman's Avatar
1saxman
Ba-da-bing! A winner every time! Step right up, folks, just one thin dime!
mountain dewd
Nov 27, 2015 04:13 PM
primered
Mar 19, 2009 11:16 PM
ridgerider3
Jan 21, 2009 04:21 PM
brentleedragon
Oct 24, 2008 03:30 PM
boatnfish
1997 - 2003 F150
Apr 28, 2008 04:36 PM
