Intermittent Throttle Glitch
Old Mar 8, 2014 | 05:16 AM
Mcrafty1's Avatar
Mcrafty1
I talked about this some earlier....but I can't remember if it was on this site or another one ( I cruise a few others) Anyway, I'll bring you up to speed now.
When plowing in the past, three or four different times when I would make my shift to start ahead with a pass the throttle would be dead. Now this was just for a split second really, by the time I realized it happened it would recover and work fine. and the only time it happened was when I was attempting to start ahead from a stop. That being said it hasn't done it the last couple of times I plowed and I have no codes that I can find.
I haven't pursued this any further at this time because I really don't have a direction to go. I'm kinda looking at this as maybe just an electrical glitch (like maybe the transmission hadn't settled in to where it needs to be as quick as usual and that may have affected the throttle switch or something along that line, Idk) I was wondering if anyone has ever had this happen before?
I also will add that my FICM was in the range that everyone says is safe 47.5 to 48.5 and my ICP is well within range of where it should be Idleing hot at around 580 +/- and snaps up from there real quick. Thanks for any input. Sorry for the kinda long post but I wanted to try and be clear with what was happening.
Old Mar 8, 2014 | 08:54 AM
acf6's Avatar
acf6
good luck..been dealing with this issue since christmas
Old Mar 8, 2014 | 09:20 AM
Mcrafty1's Avatar
Mcrafty1
Any ideas?
I had one poster on another site tell me to check my wiring down around mt foot peddle, but it hasn't done it since before he mentioned that so I haven't delved into it...I'm thinking the old 'ignore it and maybe it will go away' method but..........I don't really want to have to strap on my hiking boots either so I'm all ears here.
Old Mar 8, 2014 | 09:27 AM
acf6's Avatar
acf6
do you have non adjusable or adjustable pedal?
Old Mar 8, 2014 | 09:50 AM
cheezit's Avatar
cheezit
Ever have issues whith shuttering going in to reverse?
Old Mar 8, 2014 | 03:38 PM
Mcrafty1's Avatar
Mcrafty1
Yes! I've had mine do that a couple of times too, I don't recall the two issues happening at the same time though.
Both issues where when I was plowing snow though.
Old Mar 8, 2014 | 05:41 PM
cheezit's Avatar
cheezit
Do some research on the low reverse solenoid. It may fit your concern.
It was the first thing that came to my mind for a possible cause of the issue
Old Mar 8, 2014 | 08:21 PM
Mcrafty1's Avatar
Mcrafty1
Ok, thanks I'll see what I can find.
Old Mar 8, 2014 | 08:25 PM
Mcrafty1's Avatar
Mcrafty1
Sorry about not getting back to answer your question earlier, for some reason FTE don't send me notifications when my posts have been responded to.........and the answer to your question is non-adjustable peddles.
Chris611
6.7L Power Stroke Diesel
Apr 4, 2014 09:37 AM
BillyBob69
Mar 2, 2011 08:02 PM
Oversize
13
Mar 20, 2009 06:18 AM
HTi-Enright
Feb 15, 2008 03:12 PM
kjswensen
Nov 4, 2006 01:26 PM
