ok here goes nothing. i am going to try and explain my problem. i posted about a month ago describing my throttle problem. i would be at a stop and depress the throttle but not have any response, the check engine light would come on and then go away within seconds. i tried some lube on it but only helped for about a week. i started looking more into the throttle and notice what seems to be a nutreul sensor it releases when i depress my throttle, well it looks to be chipped away and is about to fall out of its house. if anyone knows what i am talking about could you let me know what is called and if i need a entire new pedal assembly or if there is some thing else i can do to fix????
Sounds like that may be your problem. I have been seeing a few of these threads lately. I think the dealer will only sell the whole assembly. Some one will come in here and let you know for sure. I am kind of bumping this.
HTi...I found it. Here is the best I can do.....
Search THIS forum for....Throttle Replacement
Go to the 4th page.
Open 1st thread.
Read 2nd post.....from Action4478
Click there
