Hi Idle Kit
Old Mar 7, 2014 | 05:36 PM
avfrog's Avatar
avfrog
Originally Posted by Mcrafty1
The running lamp light on the headlight ****? when you pull out the ****? is that what you mean? Thanks
Yes, but turn it clockwise to running lamps, not pull out for fog lights. You could use any of those options though. I just really didn't want to drill and mount a cheesy toggle switch on my dash, and I don't have the upfitter option.
Old Mar 7, 2014 | 06:26 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Here is how I did my Hi-Idle switch...
Up is BCP and down is PTO
Josh
Old Mar 7, 2014 | 06:39 PM
KDAVID1's Avatar
KDAVID1
Newbie question
What is the purpose for manually turning on high idle?
Old Mar 7, 2014 | 07:11 PM
Bullitt390's Avatar
Bullitt390
Originally Posted by KDAVID1
Newbie question
Cold Warm-up
Jump Starting
Extended Idle
Running power hungry accessories
Josh
Old Mar 7, 2014 | 07:44 PM
Mcrafty1's Avatar
Mcrafty1
Originally Posted by avfrog
Yes, but turn it clockwise to running lamps, not pull out for fog lights. You could use any of those options though. I just really didn't want to drill and mount a cheesy toggle switch on my dash, and I don't have to upfitter option.
Ok, I wondered what that function was for....my running lights must have been turned off somehow so that function isn't even being used now and will serve well for my high idle switch.Thanks
Old Mar 7, 2014 | 07:59 PM
KDAVID1's Avatar
KDAVID1
Originally Posted by Bullitt390
Cold Warm-up
Jump Starting
Extended Idle
Josh
Ok--so on cold warm up--the high idle gets the temps up quicker-which is best?
in general it is best for these engines to run at a higher RPM for the health of the engine correct.
Old Mar 7, 2014 | 08:13 PM
Bullitt390's Avatar
Bullitt390
Well... Something like that. I do not believe in the wet-stacking theory. However, it does warm up the engine faster and helps the electronics, especially the FICM with a higher idle.
Josh
Old Mar 7, 2014 | 08:28 PM
Yahiko's Avatar
Yahiko
You could also hide a switch in that small storage
tray down low center of the dash.
Sean
Old Mar 7, 2014 | 08:35 PM
KDAVID1's Avatar
KDAVID1
Josh
I gotcha--makes sense on the electronics--thanks.
Old Mar 8, 2014 | 05:00 AM
Mcrafty1's Avatar
Mcrafty1
Thanks to all, just one of the great things about FTE, lots of experience and willing people to share it. It really does make owning a Super Duty 6.0 much easier.
I'm off to the body shop to pick my truck up today and will start to make preparations to get this high idle thing done.
Old Mar 8, 2014 | 07:56 AM
ultrasks700's Avatar
ultrasks700
I just did the high idle switch in my 2004. Took 1/2 hour to do. I dont see any reason to idle over 1200rpm...stock goes to 1000 in cold weather, so the high idle switch brings it up just a hair more. Takes about 10 minutes to bring my truck from dead cold to about 140 degrees Engine coolant temp(via Edge insight)
Old Mar 8, 2014 | 10:08 AM
avfrog's Avatar
avfrog
From the factory the truck idles up, but then starts to idle back down pretty quick. I done the mod to kick it up and keep it there until I shut it off.
Also when it's down in the single digits, idleing will let the engine temp fall and then it takes a few miles to get back up to temp. Or, use high idle and keep it up to temp.
Old Mar 8, 2014 | 10:23 AM
  #28
Mcrafty1's Avatar
Mcrafty1
That's what I'm looking to do, when I get with my truck I'll check out the wiring and see if I can get it to do the same. Thanks.
Old Mar 8, 2014 | 10:28 AM
  #29
Mcrafty1's Avatar
Mcrafty1
Same here, It's been extremely cold for awhile here now in the NE, this morning was the first morning for some time that it was above Zero, and as you say whenever I stop the truck the engine cools rather quickly and then it takes a bit ti get it back up to OT, I haven't put on a winter front because I plow with this truck and with the plow on traveling it keeps the engine on the warm side anyway and I don't want to mess with opening and closing the front every time I hook/unhook the plow.
mattymax
Jan 22, 2020 12:08 AM
Sled_000
Apr 15, 2018 12:04 PM
toymaster
Mar 30, 2018 11:55 AM
weekendwarriorfsw32
May 3, 2007 08:31 PM
Zinfinity
Sep 11, 2005 01:16 PM
