BD High Idle Kit
Old Feb 10, 2019 | 08:52 AM
mattymax's Avatar
mattymax
BD High Idle Kit
Just a question about guys with the BD high idle kit. Once this is installed all you need to do it set the parking brake and set your idle speed ?
I'm deciding on wiring up myself with a resistor to the upfitter switch or just buying the plug and play kit.
I dont think I really need to adjust the RPMS much.
Thanks
Matt
Old Feb 10, 2019 | 09:39 AM
jimzpsd's Avatar
jimzpsd
I do not have one of those kits you want, but the nice feature is,........its adjustable. However, if you will settle for a fixed rpm (1400), take a look at this unit. Plug and play and no need to tap into an upfitter switch.
https://www.12volt.solutions/product..._ford~md_f-350
Old Feb 10, 2019 | 09:33 PM
f350ktm's Avatar
f350ktm
Originally Posted by mattymax
Just a question about guys with the BD high idle kit. Once this is installed all you need to do it set the parking brake and set your idle speed ?......
Yep, it's that simple. Touch the brake pedal and it kicks off.
Works great with remote start.
Old Feb 10, 2019 | 09:40 PM
bigt8600's Avatar
bigt8600
just to be clear, I come home from work. Park and engage e-brake. next morning I can remote start and it will high idle to whatever I have it set at?
Looks like an easy solution to me unless i'm missing something.
Old Feb 10, 2019 | 09:51 PM
mattymax's Avatar
mattymax
I like because 1) plug and play 2) Clean install 3) don’t have to remember to flick the upfitter the night before
If it wasn’t for cold start, warming up I would probably just spend the $5-$10 and wire up the resistor mod
Matt
Old Feb 10, 2019 | 09:54 PM
bigt8600's Avatar
bigt8600
Matt
I like the BD kit but don't see the option to order the mount I saw in the Youtube video. The 12v solution may be the easiest if 1400 rpm is optimal for this sort of thing. I have no experience with this but don't see why I would need anything over that rpm level.
Old Feb 10, 2019 | 10:13 PM
f350ktm's Avatar
f350ktm
Yes. I am very happy with mine unless I forget to engage the E brake!
Old Dec 7, 2019 | 04:29 PM
Martin6's Avatar
Martin6
Does this kit (1036612) disable the upfitter switches? I read an application note on a vendors page that said: "Installation requires disconnecting the factory upfitter switches."
So does this mean my existing auxiliary lighting connected to my upfitter switches will no longer work if I install this kit?
Old Dec 7, 2019 | 07:11 PM
f350ktm's Avatar
f350ktm
Unless something has changed with this kit since I installed mine earlier this year, no.
I have factory upfitters with lights and compressors connected and the high idle kit has had no impact on their operation.
I would be interested in the source of the application note you have referenced as I don't see how the kit could possibly inactivate the upfitters.
Old Dec 7, 2019 | 07:39 PM
TeddyD's Avatar
TeddyD
Could just do the potentiometer install and have adjustable rpm with no need for the e-brake to be engaged. There’s a few YouTube videos of that install.
I did the basic resistor high idle that brought it up to just over 1200rpm. Works great with the up fitter switch and e-brake engaged.
Old Dec 7, 2019 | 08:07 PM
Martin6's Avatar
Martin6
OK good. Thanks.
I didn't think the kit would inactivate the upfitter switches, but...
High Idle KIt
Old Dec 7, 2019 | 08:26 PM
sxrfun's Avatar
sxrfun
According to the install instructions the upfitter switches are indeed unplugged.......interesting
Old Dec 7, 2019 | 11:39 PM
jrwinger's Avatar
jrwinger
I believe it may be a misprint in the BD-Power install instructions. As F350KTM said, the upfitter DO still work with the BD high idle installed.
The upfitter harness is under the hood, not in the passenger kick panel. I am not 100% sure what the passenger kick panel harness is called though.
I could be wrong....wouldn't be the first or last time.
Old Dec 8, 2019 | 03:06 PM
DL222's Avatar
DL222
The 12volt.Solutions looks like it is as easy as it gets. But $90?
Can you do the same thing by tying (GN/OG to YE/GN) and put a 20k ohm resistor between (GN and BU/WH)?
I'm not sure so just asking? It would be a lot cheaper and pretty easy?
Old Dec 8, 2019 | 03:28 PM
75Mike's Avatar
75Mike
I think I'm missing something, too. Wouldn't a length of broom handle wedge against seat to the pedal do the same thing?
