pully
Old Mar 3, 2014 | 09:35 AM
jeepy's Avatar
jeepy
pully
adding power steering to 66f100 with 352 engine what pullys do I need crank and water pump or altenator also
Old Mar 3, 2014 | 11:16 AM
daveengelson's Avatar
daveengelson
Welcome to FTE!! :-. Am certain member will be correcting me; having said that, there's a part # or Casting #(?) on the pulley, if you can post the numbers , and how many sheave (groove) pulley, then perhaps member can make suggestions. Had same issue only with a 302 installed in the 65, found I had an unmatched set. If member(s) are unable to help?, purchased a pulley thru ebay by contacting a particular seller, told him what I was trying to accomplish and provided him the casting #'s, he responded w/ a list of options and either had the item on auction or could get it. For $30 ended up replacing the crankshaft pulley and problem solved. If decide to go this route I probably able to locate the mentioned seller's ebay email address, or run an ebay search under Ford pulleys and find a seller with majority listing of Ford engine pulleys and parts??
Posting a link to pulley chart but make sure to do your research, may be inconsistency between this chart and Ford pickup master catalog p/n??
Pulley
Old Mar 3, 2014 | 11:22 AM
jeepy's Avatar
jeepy
my harmonic balancer has a single v belt grove in it.water pump and altenator one grove balancer has 3 taped holes to bolt a pully on I thank my truck is a 352v8
Old Mar 3, 2014 | 12:00 PM
Tedster9's Avatar
Tedster9
If you scoot over to Mummert's http://www.ford-y-block.com he should be able to hook you up with what you want.
Old Mar 3, 2014 | 06:54 PM
bertha66's Avatar
bertha66
I fond a bolt on pulley from a 66 Galaxie and put it on the harmonic balancer and ran the belt from it to the P/S pump, did not need to go around the water pump.
Old Mar 3, 2014 | 07:01 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by bertha66
I found a bolt on pulley from a 66 Galaxie and put it on the harmonic balancer and ran the belt from it to the P/S pump, did not need to go around the water pump.
C1AZ-6A312-D .. Single Sheave Outer Pulley-bolts to harmonic balancer / Obsolete
1961/67 Galaxie/LTD 352/390 / 1966/67 F100/350 352.
NOS ONLY in San Jose CA has 1 = 800-667-6659.
TISON MOTOR CO. in Estill SC has 1 = 803-625-2551.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
NOS PARTS LTD in Waxahachie TX has 7 = 972-937-2201.
Old Mar 3, 2014 | 07:12 PM
Shadowrider123's Avatar
Shadowrider123
I found a ac, ps FE truck and pulled all the brackets and pullys off of it.
That's the way to go.
Old Mar 4, 2014 | 02:19 AM
NumberDummy
1968/76 F100/350 360/390 use a different harmonic balancer and outer pulleys than 1965/67 F100/350 352.
So, you will have to use this harmonic balancer and pulley on your truck.
Old Mar 4, 2014 | 08:32 AM
User 71024's Avatar
User 71024
the 352 I pulled out of my manual steering 65 F-100 has 2 sheaves if you're interested.
Old Mar 4, 2014 | 03:38 PM
jeepy's Avatar
jeepy
thanks
Thank you everybody ordered the pulley from MILLER Obsolete bolts on the harmonic balancer
F-250 restorer
Mar 3, 2019 12:38 PM
Badmoonreizen
18
Apr 20, 2016 06:34 PM
73F100*8Mile
20
Jan 5, 2008 07:24 AM
tlb
Aug 9, 2006 01:13 AM
Jag Red 54
Jun 28, 2005 09:08 AM
