Need pulley help!!
Old Apr 14, 2016 | 05:04 AM
Badmoonreizen's Avatar
Badmoonreizen
Need pulley help!!
All of you have been so helpful in the past, I thought I might impose upon you again for a little help.
I have put my 1956 C600 on a 2003 E350 chassis. Moving along swimmingly. I purchased a Borgeson Saginaw steering pump(v groove pulley) to go on my 1971 Ford Torino 302 sbf engine. Bolted on quite nicely, but now I need a two groove crankshaft pulley to power the pump.
The original crank pulley has the 4 mounting holes and the large diameter center hole. It measures almost 7 inches across. I have looked everywhere on the internet, called most of the suppliers and manufacturers and can only find a double groove pulley with a width of 5.5 inches, which means an underdrive. March Performance Crankshaft Pulleys 1631 - Free Shipping on Orders Over $99 at Summit Racing
Does anyone have any idea where I can find the appropriate sized 2 groove v-belt pulley, or suggest a feasible alternative?
Regards, Mark.
Old Apr 14, 2016 | 08:09 AM
Badmoonreizen
An addendum to my initial inquiry:
The original single groove Crank pulley has the Ford part # D0OE-6312-A. The interchange part # for a double groove pulley is D0OE-6312-B, but the pulley is almost 8" wide.
Does this mean it will overdrive? Does it matter? Will it work? There are plenty of these on ebay for a reasonable price.
Old Apr 14, 2016 | 11:07 AM
Chilly Willy in Cali's Avatar
I bought one on eBay I'll check the number. It's about 8 inches although it's a triple. I'm going serpentine, so I'm going to sell it.
Old Apr 14, 2016 | 11:09 AM
It's a D0AE-6312-C....
Old Apr 14, 2016 | 01:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The original single groove Crank pulley has the Ford ID Engineering # D0OE-6312-A.
The interchange ID Engineering # for a double groove pulley is D0OE-6312-B, but the pulley is almost 8" wide.
Your info is flawed, no part numbers are marked on parts since 1956.
Ford replaced the pulley marked with ID Engineering # D0OE-6312-A with Ford part number: DOZZ-6A312-A which is a Triple Sheave Pulley.
Pulley marked with ID Engineering # D0OE-6312-B is Ford part # D0OZ-6A312-E Double Sheave Pulley.
Post 4: Marked with ID Engineering number: D0AE-6312-C = Ford part number D0OZ-6A312-B .. Triple Sheave Pulley, has different applications than D0ZZ-6A312-A Triple Sheave Pulley.
Old Apr 14, 2016 | 01:36 PM
my pulley is marked....
Old Apr 14, 2016 | 04:43 PM
Badmoonreizen
Pulley
Thanks Chilly *****, but I can't use a triple sheave.
I knew Bill would come through, but my single pulley is clearly marked with the part # and a Ford logo. Maybe it's not original to the 1971 302, but it's on there. Thanks for the proper number, Bill.
I spoke with the March pulley technical expert, and he had no solution, since the water pump pulley is also 6 1/2 ". His solution was to change all the pulleys, but that isn't happening. He also told me it is better to overdrive than to underdrive, so I am going to go with the 8" crank double sheave pulley.
Seems to be plenty of those on ebay for a reasonable price.
Regards, Mark.
Old Apr 14, 2016 | 05:19 PM
Is your single sheave 8 inches? If its smaller you might run into clearance issues with the eight inch crank pulley and a 6 1/2 water pump pulley.
Just something to checkout
Will
Old Apr 14, 2016 | 06:04 PM
Badmoonreizen
Will: The single sheave pulley is 6.56". It looks like I have to experiment. It's cheaper to buy the double sheave for under $50.00 than buy all billet pulleys for $300.00.
I'll post the results when I try it out.
Thanks for the response.
Old Apr 15, 2016 | 03:31 PM
Badmoonreizen
Number Dummy
Bill:
Attached is a photo of my single sheave pulley. The part # and Ford logo are right there in plain sight!
Old Apr 15, 2016 | 04:35 PM
NumberDummy
Bill:
Attached is a photo of my single sheave pulley. The part (sigh) # and Ford logo are right there in plain sight!
But, it is not a Ford part number, it's the ID Engineering Number.
There are no Ford part numbers marked on parts after 1956, just casting or ID Engineering numbers when applicable.
Parts catalog pic: Read the description for Ford part number D0ZZ-6A312-A and you will see Ford ID Engineering number: D0OE-6312-A
Old Apr 15, 2016 | 04:51 PM
Badmoonreizen
AHA, now I understand your point.
Thanks for the further enlightenment.
Mark.
Old Apr 15, 2016 | 04:56 PM
In the second hand market. it would be safe to call a number that's stamped on that part,that is unique to that part, a part number .
Old Apr 15, 2016 | 05:19 PM
NumberDummy
Uh huh... Go right on ahead, call it a part number, but lotsa luck finding one using the ID Engineering Number!
There are 3 websites used to search for NOS obsolete parts, the Ford part number is required for all.
Old Apr 19, 2016 | 03:24 PM
Badmoonreizen
Well, now I am screwed. As Will suggested the double sheave is too big to fit on the crank because of the nose on the water pump. To add insult to injury, I went to the Monroe swap meet Sunday, and there were hundreds of crank pulleys that I could have purchased for $10.00 or under. I spent almost $50.00 for the same pulley.
I need to find a short water pump and that will solve the problem, I hope. Is there a number for a short one that will fit a 1972 Ford Torino small block(302) engine? I also need a pulley that will fit.
Maybe the number dummy can scrounge up a PART NUMBER for me. Bill always comes through!!
Thanks, Mark.
