E4OD gears down automatically???
Old May 16, 2014 | 09:25 AM
andym's Avatar
andym
Lead Head's correct. If it's a PSD, it's OBD-II. It will still have transmission codes but you need and OBD-II reader to get them.
Old May 16, 2014 | 09:29 AM
AWSHUX's Avatar
AWSHUX
The engine revs like it's in neutral when it's messing up. It acts like it's low on fluid. If I rev it real hard (I know that isn't good) it'll move just a little bit. But it goes right into reverse, just not forward.
Old May 16, 2014 | 11:29 AM
Lead Head's Avatar
Lead Head
Next time it messes up, push the Cancel O/D button, and see if it moves.
Old May 16, 2014 | 12:22 PM
AWSHUX's Avatar
AWSHUX
Ok, I will try the Overdrive button next time.
The scanner I been using is a OBD-II. So it should read the trans,,, right?
Old Oct 30, 2014 | 02:22 PM
AWSHUX's Avatar
AWSHUX
Hey guys, sorry I'm just now getting back on here. The OD button don't help. My OBD-II scanner still shows no codes, is there another place to pull the codes? I've since changed the fluid and filter with no improvement. The truck runs flawlessly after it's been sitting for a while and the motor and trans is cool. Could it be the solenoid pack that's gone bad? The truck pulls like a train when it's in gear, with no slipping at all. It's only after it's taken out of gear, that it won't go back in gear, after it's been ran a while. I visually inspected the wiring to the trans and all seems to be ok. Is there a way to check the solenoids? Could the TPS cause this?
Old Oct 30, 2014 | 11:33 PM
dixie460's Avatar
dixie460
If your scanner can read Ford-specific data points then one of the parameters you should be able to read is transmission oil temp. My ScanGauge II does but I had to tell it where to look for the data first. That's what I use for my trans temp gauge.
Try unplugging the harness from the transmission and driving it. The trans should default to 2nd gear (?) and if it moves without slipping then you know it's an electrical issue.
Old Nov 2, 2014 | 11:46 AM
choate's Avatar
choate
Originally Posted by rla2005
Clean the pins on the data link connector with contact cleaner or a small nail file. This a very common problem, the pins corrode.
Where is the data link connector located?
Old Nov 2, 2014 | 12:42 PM
joshh's Avatar
joshh
the 97 and older power strokes are not true obdII they have to have a scanner designed to read them. Most generic obdII scanners wont read them which is probally why your not getting any codes
Edgethis
Jan 9, 2012 10:11 AM
my91stealth
15
Dec 22, 2010 04:46 PM
Toyman
Dec 28, 2006 09:11 AM
boatbuilder
Dec 1, 2005 08:18 PM
RLKBOB
Nov 6, 2004 10:29 AM
