Another E4OD problem
Old Dec 27, 2006 | 09:12 PM
Toyman's Avatar
Toyman
I will try to be brief. Here is the situation, 143K miles on truck, 1994 F250 5.8L 4X4. It has happened about 4 times, the transmission will just shift into 2nd gear while travelling at highway speeds (70 mph) the truck doesn't try to gain speed it just slides to a different gear. It has also had an extemely hard shift from time to time, all gears.
The fluid is very clean, good color, no burnt smell, and no leaks.
The Od light has not flashed, and does work properly.
Any help, is it the begining of the end?
Toyman
Old Dec 28, 2006 | 08:37 AM
projectSHO89's Avatar
projectSHO89
The service manual has a diagnostic procedure in which the vehicle is exercised in a specific pattern, then the codes are read.
This helps to get a preliminary set of data so a diagnosis can be started.
Steve
Old Dec 28, 2006 | 08:47 AM
Toyman's Avatar
Toyman
But, there are no codes. I've hooked it to our scan tool at work.
Toyman
Old Dec 28, 2006 | 09:11 AM
Casey's Avatar
Casey
Replace the Transmission Range Sensor (TRS.) It's the sensor on the driver's side of the trans, where the shift cable attaches.
As it starts to fail it does just what you're seeing. It will do it for a long time before it gets bad enough to set a code. Usually the trans is destroyed before a code is set.
Toyman
Michigan Chapter
Jul 13, 2016 04:05 PM
Toyman
Jan 5, 2013 10:39 AM
Toyman
Michigan Chapter
17
Jul 9, 2012 07:47 PM
Toyman
Michigan Chapter
Dec 26, 2008 09:45 PM
Toyman
Aug 20, 2008 03:41 PM
