Need fuel heater help.
Old Mar 1, 2014 | 10:02 AM
Tim J's Avatar
Tim J
Last night 5deg of course, my truck shut off on the way home. Rail mounted fuel pump not running. No "Wait to start" Light. So I got it towed home. After trying all the normal stuff (CPS etc) I found fuse 30 under the dash was blown. Disconnected fuel heater, new fuse and started right up. Could a fuel heater cause this fuse to blow? Its original. I do have a 6pos chip. but its never caused a problem. Any input would be great. Thanks, Tim
Old Mar 1, 2014 | 10:09 AM
02f300's Avatar
02f300
Tim J,
That is a common failure.
The fuel heater in the filter bowl fails over time and can short out causing the fuse to blow.
When that fuse blows you get no start.
Carry a spare fuse actually you should carry a fuse kit with a tester and spare fuses.
Tony
Old Mar 1, 2014 | 10:34 AM
Tim J's Avatar
Tim J
I didn't know to look there until this morning. It felt like cps failure at first. Do you know if I can run in the winter with out it for a day. I have treated fuel. Thanks
Old Mar 1, 2014 | 10:48 AM
crop harvester's Avatar
crop harvester
several people run without it,some people fill more comfortable keeping the heater operational in extreme cold temps, Im one of those worry warts that bought a new heating element.
Old Mar 1, 2014 | 11:01 AM
sand_fiend's Avatar
sand_fiend
Fuel Bowl Heater Element - Riffraff Diesel Performance
Also, check the 42 pin motor wire harness plug on the driver side valve cover. some times it falls down and rubs the valve cover. the lowest wire in the harness happens to be the wire for the Fuel bowl heater. over time it will rub through and short out on the valve cover there..
Old Mar 1, 2014 | 11:05 AM
abowman's Avatar
abowman
i ran without one for 2 years, and then finally got a new one. i never noticed a difference on weather i had one or not.
Old Mar 1, 2014 | 01:56 PM
Tim J's Avatar
Tim J
I have a Dorman 904-210 on order. Its still below 0 here in the morning....so i decided Id better replace it. In the 9 years Ive had this truck..... its always started in the cold. Thanks everyone!
Old Mar 1, 2014 | 04:43 PM
jr2000sd's Avatar
jr2000sd
I was thinking would it be a good idea to run the heater on a switch so if its cold you can turn it on?
Old Mar 1, 2014 | 07:27 PM
Tim J's Avatar
Tim J
Does anyone know when it is ON?
Old Mar 1, 2014 | 07:44 PM
Franko72's Avatar
Franko72
Molon Labe
Here is some info I found for ya. Post #9 has some good info.
Mine has been unplugged for years. Yes, yes I know. I'm in Florida
https://www.ford-trucks.com/forums/1...-critical.html
Old Mar 1, 2014 | 08:17 PM
Tim J's Avatar
Tim J
Thanks Franko72. That thread answered my questions. I am going to put a temporary led indicator to let me know when it is on. My e99 is cold blooded and will start down to 0 using my remote start and no block heater. Colder than that and I start it manually, unless ive plugged it in.
Old Mar 2, 2014 | 01:33 PM
Bob Taulbee's Avatar
Bob Taulbee
Duct Tape Tech.
Just for info. If you unplug the fuel bowl heating element, it will also disable the water in fuel light. To get around this open the fuel bowl and disconnect the heater from the inside of the fuel bowl, and leave the external connection connected that way the water in fuel indicator will still work.
Old Mar 2, 2014 | 03:33 PM
Tim J's Avatar
Tim J
I replaced the heater this morning. My e99 had the early plate and wire style, but the newer style seemed to fit just fine. Thanks again everyone!
70spoiler
Mar 30, 2014 03:45 PM
coreymck
13
Nov 30, 2012 10:41 PM
ol-blu
Nov 13, 2012 02:36 PM
Oslo
Jul 14, 2011 07:40 PM
ddubya61
Nov 29, 2006 11:00 AM
