Adjustable Track Bar
Old Mar 2, 2014 | 01:03 PM
jbravata2's Avatar
jbravata2
How much or a difference will one of these make? I'm trying to straighten out my steering and front end. I have a 4" suspension lift. I ordered a new pitman arm and steering gear to help my steering and in my research I discovered the adjustable track bar. Anyone have any input on these?
thanks Jason
Old Mar 2, 2014 | 01:37 PM
JOHN2001's Avatar
JOHN2001
All the track bars are adjustable there also refered to as inner tie rod ends. I suggest ordering all new tie rod ends.
EDIT: Do your self a favor and have someone jump in the driver seat and turn the wheel back and forth while you look at all your tie rod ends moving back and fourth and inspect everything else moving. The truck doesn't have to be running but you may need to have the key in the ignition so the wheel doesn't lock. I just did this yesterday and found that my pitman arm is junk.
Old Mar 2, 2014 | 03:09 PM
takotruckin's Avatar
takotruckin
The tie rod ends are on the steering links. The track bar is the big bar that connects the axle to the frame and keeps it from moving side to side.
An adjustable bar may be necessary to center the axle at ride height, if your axle is off center considerably, you should consider one.
What pitman arm did you order? A drop pitman arm should only be used with a drop track bar bracket to keep the suspension/steering geometry correct.
Old Mar 2, 2014 | 03:25 PM
JOHN2001's Avatar
JOHN2001
What was I thinking...... I guess my mind is all over the place since I realized I broke a pinion..... Sorry
Old Mar 2, 2014 | 03:28 PM
Stewart_H's Avatar
Stewart_H
Ford power steering pumps don't like having the steering wheel turned back and forth very much. A little movement is ok, but if you steer/turn the wheel too much, you'll puke fluid out of the power steering unit if the engine is off.
Stewart
Old Mar 2, 2014 | 03:47 PM
jbravata2's Avatar
jbravata2
I ordered a Pro Comp FD500; pitman arm for a 4"-6.5" lift from Summit. They didn't include any suggested parts, this is all new to me some any and all input is greatly appreciated! I'll have to look up a track bar drop bracket. Would that still be needed with an adjustable track bar??
Old Mar 2, 2014 | 03:52 PM
takotruckin
Yeah, you will still need it. You want to keep the track bar at about the same angle as the tie rod that connects to the pitman arm.
33500 - 2000 - 2004 Ford Super Duty F250 / F350 Pan Rod Drop Bracket - ICON Vehicle Dynamics
Old Mar 2, 2014 | 05:11 PM
jbravata2's Avatar
jbravata2
I'll have to add that and an adjustable track bar to my wish list!!
Old Mar 2, 2014 | 06:01 PM
takotruckin
Yeah, I've had a drop pitman, trackbar bracket and adjustable track bar on my wish list for a while, along with hydro assist steering. But then the truck needed brakes and hubs, and then it needed the tie rod ends replaced... and so it goes.
Old Mar 2, 2014 | 07:01 PM
jbravata2's Avatar
jbravata2
It seems like the more time I spend in this forum the longer my wish list gets!! Now I need to research hydro-assist power steering!
Old Mar 2, 2014 | 07:04 PM
takotruckin
You know how you can't turn your steering wheel while sitting still with the brakes depressed (maybe yours isn't that bad, but mine is)? It takes care of that . Also helps prevent the sector shaft in the steering box from breaking, which is always a fear of mine while wheeling.
speakerfritz
Sep 29, 2017 04:57 PM
jswartz84
Apr 14, 2017 12:34 AM
pin8246
Aug 29, 2012 02:12 PM
edub32
Apr 1, 2009 11:07 PM
Storm
Oct 28, 2007 09:53 PM
