Blown #30 fuse
Old Nov 30, 2012 | 07:59 AM
coreymck's Avatar
coreymck
Blown #30 fuse
I resently made the rookie mistake of pulling the chip out while my truck was running and frying the pcm. I found a used one hooked up works great. It's been about 3 weeks now since I did that and my father jumped in my truck to move it and didn't wait for the wait to start light to go started blowing the #30 fuse. Ever since that happen two days ago I've been blowing like 2 or 3 a day. Could this be because I'm pulling on the steering wheel while getting in, and something touched that wasn't saposed to thanks for the help
Old Nov 30, 2012 | 08:02 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Unplug the fuel bowl heater on the back of the fuel bowl and replace the fuse and see if it stops blowing. This is very common on these trucks.
schlepprock250's Avatar
schlepprock250
Sounds like the fuel bowl heater is shorting out..unplug the fuel bowl heater(white plug on the back of the fuel bowl) and you should be good to go..THEN replace the fuse..
Old Nov 30, 2012 | 08:19 AM
Pitcrw6's Avatar
Pitcrw6
You can leave it unplugged till you get a new fuel bowl heater or just leave it alone. If you live in a cold area then you might want to replace it.
Old Nov 30, 2012 | 09:29 AM
just another truck's Avatar
just another truck
I am here in Michigan, I have not had a fuel bowl heater in 4-5 years.. Leave it unplugged..
Old Nov 30, 2012 | 09:51 AM
coreymck's Avatar
coreymck
Thanks guys I'm not going to plug it back in seeing I live in Sarasota florida shouldn't bee a problem
Old Nov 30, 2012 | 10:00 AM
just another truck
Ohh.. are you sure, what does you windchill get down to
Old Nov 30, 2012 | 10:02 AM
miller_feed
That plug also lets you know when you have water in fuel. I would change the heater and plug it back on.
Old Nov 30, 2012 | 10:17 AM
coreymck's Avatar
coreymck
Maybe 30 lowest
Old Nov 30, 2012 | 11:10 AM
just another truck
Maybe 30 lowest
I was kidding...
Old Nov 30, 2012 | 04:10 PM
1996pwrstrk's Avatar
1996pwrstrk
That's not windchill down there it's called a breeze .
Old Nov 30, 2012 | 05:35 PM
PaysonPSD's Avatar
PaysonPSD
FTE Remembers
If you want the WIF indicator but don't need the heater then just remove the heater element or disconnect it in the fuel bowl. Then you can plug the connector back in for WIF.
Old Nov 30, 2012 | 10:12 PM
sand_fiend's Avatar
sand_fiend
If it blows again, You need to check the 42 pin plug on the driver side valve cover. the wires on the lower side of the wiring harness rub the valve cover and rub through the wires. normally it always seems to be that wire that rubs through first..
Old Nov 30, 2012 | 10:41 PM
howellt39's Avatar
howellt39
X2 on the driver's side VC, that got me once and had to ride home on the hook.
Tim J
Mar 2, 2014 03:33 PM
lspencer001
Nov 23, 2011 09:04 PM
Oslo
Jul 14, 2011 07:40 PM
Jfrei
Jan 12, 2009 02:21 PM
ddubya61
Nov 29, 2006 11:00 AM
