Painting Plastic?
Old Feb 24, 2014 | 01:29 PM
BogTroll's Avatar
BogTroll
Painting Plastic?
I'm looking at redoing the plastic parts (door panels, kick panels etc.) in the cab of my '78 F350 Custom dump. Not all of the parts match in color. Some are original, and some are "better ones" that I've collected along the way. Is there any special paint or prep needed? I'm not interested in having it just look good the day I do it, but to have it last.
Thank you in advance
Old Feb 24, 2014 | 01:51 PM
Jklnhyd's Avatar
Jklnhyd
I used this Rustoleum, that i bought from AutoZone, yesterday.
FYI, it does NOT work on the armrest rubber. I tried it one one that i had here, and the paint is tacky after about 22 hours.
Old Feb 24, 2014 | 02:57 PM
Jklnhyd's Avatar
Jklnhyd
This is what i used on the armrests. Seems to stick well, super pliable. Its a bit duller sheen than the Satin Rustoleum on the door panel, but you would never notice.
Old Feb 24, 2014 | 03:54 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I use Krylon "Fusion" paint to paint over plastic.
Old Feb 24, 2014 | 04:06 PM
meborder's Avatar
meborder
i used the duplicolor vinyl dye also worked GREAT on the rubber arm pad and dash:
the doors were blue, and the dash was faded to almost white.
Old Feb 24, 2014 | 05:23 PM
JP3's Avatar
JP3
SEM makes an excellent product in a variety of colors. I restored the red interior of my 83 Mustang from severely sun faded to really really nice and it has worn extremely well.
Before:
After:
Old Feb 24, 2014 | 08:16 PM
Blue and White's Avatar
Blue and White
I have used the SEM "system" with good results. Wash first, then use spray cleaner, then adhesion promoter/primer, then paint. I got the stuff through Eastwood.
Old Feb 24, 2014 | 08:35 PM
JP3's Avatar
JP3
I just washed with soap and water and sprayed. No cleaner, not promoter.
Old Feb 24, 2014 | 10:43 PM
trozei's Avatar
trozei
I've been using the Fusion stuff for years with excellent luck.
Melnickta
Dec 28, 2021 04:17 PM
SCFlareside
Jan 10, 2018 08:10 AM
KG Excursion
Jul 20, 2014 10:16 AM
GregN
Feb 17, 2012 02:51 PM
bsiebert
Oct 11, 2010 06:09 PM
