Alternator Question
Old Feb 20, 2014 | 04:36 AM
xaviar's Avatar
xaviar
Yeah, thats what I thought! Way too expensive! Thx for the link ordering one today.
Old Feb 20, 2014 | 06:18 AM
hanklin's Avatar
hanklin
I`m looking at the DC 250 but I don`t understand why I would change the pulley? More info please,,
Old Feb 20, 2014 | 06:25 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The smaller is used on the 140 amp OEM alternator. DC alternators already come with small pulleys.
Josh
Old Feb 20, 2014 | 06:26 AM
hanklin's Avatar
hanklin
Thanks Josh
Old Feb 20, 2014 | 10:45 AM
Yahiko's Avatar
Yahiko
It spins the alternator faster at idle so that you get more
power at the idle level.
Sean
Old Feb 20, 2014 | 02:22 PM
RPM371's Avatar
RPM371
Originally Posted by Yahiko
Yes ,But OUCH on that price.
Should be less
Overdrive 8 Groove Pulley Gain Output Idle in Some Apps Ford Alternator 6g 3G | eBay
Check this one out. They did a good job for me.
US $14.82
US $ 5.00
Shipping
Sean
Yep, that's the one I ordered. That on a 140 should work just fine and I won't need to upgrade my wiring.
Old Feb 20, 2014 | 02:57 PM
BLADE35's Avatar
BLADE35
You Don't have to your not Adding to much more power that its a Must
But anything Helps make your Own its cheap if you want
Look in my Pics
Ford Truck Enthusiasts Forums - BLADE35's Album: DC Power Alternator & Wire Upgrade
Old Feb 20, 2014 | 03:43 PM
Bonanza35's Avatar
Bonanza35
Bade35, got one of those for my son for Christmas at DC power and they said I didn't have to up grade the wires. Did you do that just because, or did someone say you had to?
Old Feb 26, 2014 | 01:50 PM
RPM371's Avatar
RPM371
Quick update... Installed the new 140 w/58mm pulley the other day. I decided to let my Ford Tech friend install it and he showed me the "kickstand" trick. Took less than 10 min to swap them out.
Old Feb 26, 2014 | 06:08 PM
BLADE35's Avatar
BLADE35
Well DC threw in the wire upgrade for Free
I would have made my own if they didn't
It just helps the electrical system with Better Flow and Less Resistence
elyrain
Jan 16, 2015 12:29 PM
brandon.edwards
Mar 14, 2013 09:23 AM
brandon.edwards
Feb 2, 2013 07:46 AM
yard_dawg
Feb 14, 2006 04:18 PM
mjgolob
Dec 12, 2005 04:35 AM
