What is the amperage on the oem alternator? I am upgrading because i run a lot of juice and was wondering about some tips for amperage and suggested amperage for he truck.
I have a 190 from DCPower and it doesn't until GP shut off. Guess the bigger ones do. Who knows. All i know is Mine definitely works better than stock did!
Nope it runs on battery until the glow plugs turn off. I get 12.5v or so
The part in red is an old urban myth that is not right..
Someone had posted a video that shows that is just not true.
I did a little test here at home with some charging system
test tools and also show that the alternator is charging at
startup. It just very slow in catching up with the demand
of the glow plugs.
That's what I was thinking that the 190 amp is still marginal (in relative terms) for achieving higher volts during glow plug cycle.
I'm think a 250 amp alternator, with 270 being the normally available unit being the minimum to get 14 volts with glow plugs operating.
My own alternator is rated at 160 amps peak (not sure exactly what it would be rated cold idle), and as you see in the video only gets 12.4-12.5 volts at idle with glow plugs.
It turns On Imediatly Josh tested his truck awhile Back I havent tested mine But IDK Why it would be any diffrent
It just dont look like its On since there is Such High Power demands at this specific time
